Launching Spin from Front Hatch?
#6874
02/05/09 12:31 PM
02/05/09 12:31 PM
Cap'n Vic
Newport and Naples
So OK 20 years ago when i raced OD we always launched spin from rail ... but when i watched the nationals in Bristol most of the boats launched from the front hatch and many seemed to douse into the hatch as well. some launched from the companionway ala j24 and a few still launched from the rail... So i have started to launch from the hatch and use the vee berth as a set up for the spin instead of a bag ... not all that bad ... but some of my crew still thinks we should use the rail ... of course they are not foredeck crew. I think I can leave the sheets attached into the hatch and that seems to be a plus ... why have most people gone to the hatch ... is it just because it is easier all around? and if so why do some boats still use the bag on the rail?
Vic
Re: Launching Spin from Front Hatch?
[Re: Steve Buzbee]
#6878
02/05/09 05:22 PM
02/05/09 05:22 PM
Posts: 2,668 Portsmouth, RI
Rhapsody #348
Steve - I remember when I crewed on Smiles for the 2007 NAs that they did the spinnaker in the fwd hatch, but don't recall the details. Just wondering on the following questions if you could explain what's done. - Is the spin halyard left attached, or connected just before launch?
- If connected before launch, I assume it has to run forward, outside the jib, under the jib foot, then back to the spin head. Is it less difficult than that sounds?
- Are sheets left connected after the douse?
- Does a person need to be below the fwd hatch to pull in the spinnaker, or can it be stuffed quickly enough from topside?
- How many people are forward during the douse (doing what)
[Re: Rhapsody #348]
#6894
02/09/09 01:11 AM
02/09/09 01:11 AM
Posts: 15 New York, NY, USA
misthos
New York, NY, USA
Steve - I remember when I crewed on Smiles for the 2007 NAs that they did the spinnaker in the fwd hatch, but don't recall the details. Just wondering on the following questions if you could explain what's done. - Is the spin halyard left attached, or connected just before launch? It can be done either way though keeping attached provides the set up with the least amount of work - however, foredeck needs to insure they keep the halyard clear of the jib so as not to affect jib shape/trim
- If connected before launch, I assume it has to run forward, outside the jib, under the jib foot, then back to the spin head. Is it less difficult than that sounds? Yes it is less difficult than you make it sound. Set it up clean outside the jib and you'll be fine. Picture them both doused on the deck.
- Are sheets left connected after the douse? Yes.
- Does a person need to be below the fwd hatch to pull in the spinnaker, or can it be stuffed quickly enough from topside? The quickest way is to have someone below (much easier to pull down than push down from above) but it can be done from above. I find it takes the same amount of people (either two above pulling down and pushing or one above and one below).
- How many people are forward during the douse (doing what) If the pole comes down then it could be three (one to drop and secure pole, one to pull down spin and one below pulling in spin). If the pole is doused with a few seconds earlier to allow time to secure then you need only two (foredeck pulling down and one below to pull spin in).
One general comment I would make about the hatch (or companionway) versus the rail is that the lack of needing to run the chute and repack means weight can stay on the rail rather than spending time below. This benefit of course depends upon conditions....
[Re: Cap'n Vic]
#6904
02/12/09 09:38 AM
02/12/09 09:38 AM
Posts: 186 Barrington, RI
cstoddard
Barrington, RI
I've done all the combo's
the issue with the hatch set is making sure it clears the hatch edges and doesn't get hung up If you are using the Bomar plastic hatch DO NOT SET from the hatch you may break it (250.00) it works best if the hatch opens forward so it lies flat on the deck.
Dead down wind takedowns are great thru the hatch if you are reaching in it doesn't work. Also in a big breeze you may end up with too many people forward getting it down
We have gone back to a rail set and either a leeward or windward take down as its a standard method ie if you have crew coming and going from the boat.
Charlie Stoddard Falcon #229
[Re: ]
#6909
02/13/09 10:44 AM
02/13/09 10:44 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
We do what ever is needed. Launch first from the rail then try and douse to the hatch, then launch from the hatch on the second leg. But we are always prepared to douse to the companion way - I do not think you can always count on one way to get the chute down.
Also we found that it really helps to have the foreguy mounted either at the mast base or between the mast and the hatch. With it in front of the hatch it just seemed to get in the way a lot.
David #397
[Re: B Johansson]
#6913
02/16/09 09:12 AM
02/16/09 09:12 AM
Cap'n Vic
Newport and Naples
For those looking to see the hatch launch in action: don't know which J30 this is at Key West ... but it pretty much sums up the program. Genny snugged in a bit, fordeck helping the release out of the hatch, halyard raised at the mast, guy prefed to end of pole, probably sheet prefed to just behind shroud. on Vee Jay because we have roller furling ... the foredeck rolls in the genny from his position just before the mast as soon as the spin is up and pole brought back. The Genny lazy sheet is over the front end of the top bridle, and the crew is trained to maintain a genny sheet on the front end of the pole for jibes. I was having crew problems with cockpit confusion about pole up, pole down, pole forward, pole back ... so moved spin halyard to mast, pole lift to mast and genny furl to foredeck. only thing we control from back of boat is pole down. But as I remember from the old days the first thing we did is always set up a spin halyard cleat on the mast... still goes to the turning block at base of mast just in case.
[Re: Cap'n Vic]
#6914
02/16/09 09:59 AM
02/16/09 09:59 AM
dbows
Marblehead, MA
Maybe Fat City in the photo?
52
guests, and 1
spider. |
