• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » One Design Class Rules » Bladder Type Holding Tank
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Page 2 of 2 < 1 2
Topic Options
#7091 - 03/10/09 06:37 PM Re: Bladder Type Holding Tank [Re: Steve Buzbee]
Rhapsody #348 Online   content
Class Co-President
Loc: Portsmouth, RI
I think your dimension estimates are on the large side, but don't have better data to support that without actual measurements. I do know there is no way the holding tank is larger than the potable water tank, which on Rhapsody is 18 Gallons.
Other Data to support the Tank Capacity:
Hull #371 - 14 Gallon Holding Tank
Hull #512 - 10 Gallon Holding Tank
Hull #80 - 12 Gallon Holding Tank
Hull #444 - 10 Gallon Holding Tank
I'll throw in an extra gallon on the largest shown just for you and call it an even 15....
_________________________
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#7097 - 03/11/09 07:03 PM Re: Bladder Type Holding Tank [Re: Rhapsody #348]
dbows Offline
Loc: Marblehead, MA
I think mine is 12 - 15 gallons. I know 8-10 flushes is about max before I like to off load when I am cruising.
Anyway I was really just wondering if anyone had done this - I think I will just replace with what I have.
Top
#7103 - 03/11/09 08:34 PM Re: Bladder Type Holding Tank [Re: dbows]
Steve Buzbee Offline
Loc: Highland Park, NJ
I'm curious if the post '84 models have larger tanks. Mine fills almost the entire forward storage compartment under the v-berth. To my eye, it appears to be significantly larger then the two water tanks combined. Is that what the earlier models have?
Blue Meanie J/30 #485
Top
#7104 - 03/11/09 08:50 PM Re: Bladder Type Holding Tank [Re: Steve Buzbee]
Class Co-President
Loc: Portsmouth, RI
Steve - there very well could be a difference in model years and explain why our perceptions on tank size are so different. I've attached a picture of the space between the aft end of the holding tank and the bulkhead on the aft end of the space. The tank occupies about the forward third of that space and flits flush against the bulkhead by the anchor locker. You can estimate dimensions by scaling from the size of the hose (1-3/4" OD) and the 8-1/2" x 11" paper chart taped on the tank.
You also mention two water tanks. Hull 348 only has a single 18 gallon polypropylene water tank under the port settee.
If Rod Johnstone calls in for the BOG meeting on 24 March, I'll ask him what he knows about the tank sizes.
Sanitary Piping Diagram & Valve Lineup
Bill Kneller
Rhapsody J/30 #348
Top
#7107 - 03/11/09 09:59 PM Re: Bladder Type Holding Tank [Re: Rhapsody #348]
Great picture-it's possible that my memory may be flawed. I'll have a look this weekend. By the way-that is an immaculate (and complicated) set of hoses!
Top
#7115 - 03/12/09 12:30 PM Re: Bladder Type Holding Tank [Re: Steve Buzbee]
dbows Offline
Loc: Marblehead, MA
The picture is exactly like mine. Except you could not eat off it as you could Bill's.
Top
#11141 - 02/23/11 01:28 PM Rules Interpretation: Bladder Type Holding Tank [Re: dbows]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
following is my "Rules Interpretation" on this issue
A holding tank is required with a capacity equal or greater to the original equipment (about 14 gallons) The tank must be located in the same location as the original tank. Bladder tanks are an acceptable alternative. Installation for discharge must be in accordance with the current federal and state laws
Charlie Stoddard
Falcon #229
Top
#11158 - 02/24/11 05:01 PM Re: Rules Interpretation: Bladder Type Holding Tank [Re: dbows]
Martin & Louise Offline
Loc: Victoria BC Canada
LimeLight hull 51 has a bladder, 14 gal It was installed in the early 90's. And seems to be working just fine and is good for racing. However up in Canda BC there isnt has many pump out as there is in the USA and we find 14 Gal to be a bit small when we are cruising. Thinking about putting in a tank with larger capacity 20 to 25 gal for those summer trips, plus I am not sure what the shelf life of the bladder is and wouldnt want it to fail.
Top
Page 2 of 2 < 1 2
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  cstoddard
Print Topic
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 2 Guests and 3 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
