June
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Benz @ North, David Hulse, littoraldrift, Windchill, knh555
1001 Registered Users
956,033 Dacron Main
156,472 Ananda's Refit
Topics3,945
Posts18,946
Members1,002
Most Online223
Dec 17th, 2019
Bladder Type Holding Tank #6990
02/26/09 09:36 AM
02/26/09 09:36 AM
Marblehead, MA
dbows Offline OP
dbows  Offline OP
Marblehead, MA
Are bladder type holding tanks in the same spot as my rigid tank an acceptable alternative?
David
Re: Bladder Type Holding Tank [Re: dbows] #7000
02/27/09 05:20 PM
02/27/09 05:20 PM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
David
Is your old tank defective? I will take this up with the rules committee and get back to you.
Larry Christy
Re: Bladder Type Holding Tank [Re: LChristy] #7018
03/02/09 07:31 PM
03/02/09 07:31 PM
Marblehead, MA
dbows Offline OP
dbows  Offline OP
Marblehead, MA
Defective? No just getting close to replacement time and was thinking the bladder would be a simpler install and probably a simpler thing to replace in the future.
Re: Bladder Type Holding Tank [Re: dbows] #7083
03/10/09 03:54 PM
03/10/09 03:54 PM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
Ok give me a few days. Is there a deadline?
Re: Bladder Type Holding Tank [Re: LChristy] #7085
03/10/09 04:11 PM
03/10/09 04:11 PM
Highland Park, NJ
Steve Buzbee Offline
Highland Park, NJ
I would guess there might be a pretty significant weight difference-those plastic tanks are pretty heavy (nothing like excess weight in the pointy end!)
Blue Meanie J/30 #485
Re: Bladder Type Holding Tank [Re: Steve Buzbee] #7086
03/10/09 04:15 PM
03/10/09 04:15 PM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
Dbows
What is the weight of your proposed bladder replacement?
Larry Christy
Re: Bladder Type Holding Tank [Re: Steve Buzbee] #7087
03/10/09 04:54 PM
03/10/09 04:54 PM
Actually, the empty polyethylene tanks are very light when empty (~15 pounds for 15 Gal tank). A bladder tank of similar capacity is about 6 pounds. Just look at the shipping weights in a Marine catalog for the ballpark comparison. The weight is in the stuff that fills it up! That's comparable to water or ~ 8.4 pounds per gallon.
I don't thing this is a weight issue from a class rules standpoint, but Larry will have to weigh in (pun intended...)
For my money, I want my stuff in a rigid walled polyethylene tank, not some bladder.
Re: Bladder Type Holding Tank [Re: Rhapsody #348] #7088
03/10/09 05:04 PM
03/10/09 05:04 PM
Highland Park, NJ
Highland Park, NJ
Ahhh, but the weight differential increases as the tanks get bigger. A 25 gal polyethylene tank weighs in at 44 pounds (at least according to a Defender Industries listing) while a 25 gal bladder type is still about 6 pounds. I have no idea how big those holding tanks are, but I'm pretty sure they are more than 15 gallons. 36 extra pounds carried well forward is some very serious weight-recall the debate over the stove which is carried much closer to midship and weighs in at only ~12 pounds.
If replacement was permitted, I know I would consider swapping out for the lighter tank setup-I race a bunch of J-29's in PHRF, and weight in the ends is deadly.
Re: Bladder Type Holding Tank [Re: Steve Buzbee] #7089
03/10/09 05:24 PM
03/10/09 05:24 PM
Steve - the holding tank is about 14 gallons - you can measure the dimensions and calculate the volume. Think of your 25 gallon analogy above. Cut a 55 gallon drum in half (take the smaller half) and that would be about the size of a tank you describe. No way that sucker fits in the v-berth!
We're talking about a 10 pound differential here on dry weight between a bladder tank and a poly tank. If you store a gallon of fresh water (or beer) that's pretty close to the weight differential. You'll get more mileage out of keeping the tank pumped dry.
Re: Bladder Type Holding Tank [Re: Rhapsody #348] #7090
03/10/09 05:41 PM
03/10/09 05:41 PM
Highland Park, NJ
Highland Park, NJ
No way you'll get me to store a couple of gallons of water forward of the head area! And I don't think I agree with your estimate of the size of the tank-I figure the tank is (at the top) about 3' wide aft, 1' wide forward, and about 3' long. That would be a top surface area of a little over 5 square feet. So conservatively, figure 5 cubic feet of volume (the tank is deeper than one foot, but tapers quite a bit). A gallon of water occupies .1337 cu. ft, so I would estimate 5/.1337=37 gallons.
I can't believe I just wasted so much time on...waste.
Re: Bladder Type Holding Tank [Re: Steve Buzbee] #7091
03/10/09 06:37 PM
03/10/09 06:37 PM
I think your dimension estimates are on the large side, but don't have better data to support that without actual measurements. I do know there is no way the holding tank is larger than the potable water tank, which on Rhapsody is 18 Gallons.
Other Data to support the Tank Capacity:
Hull #371 - 14 Gallon Holding Tank
Hull #512 - 10 Gallon Holding Tank
Hull #80 - 12 Gallon Holding Tank
Hull #444 - 10 Gallon Holding Tank
I'll throw in an extra gallon on the largest shown just for you and call it an even 15....
Re: Bladder Type Holding Tank [Re: Rhapsody #348] #7097
03/11/09 07:03 PM
03/11/09 07:03 PM
Marblehead, MA
dbows Offline OP
dbows  Offline OP
Marblehead, MA
I think mine is 12 - 15 gallons. I know 8-10 flushes is about max before I like to off load when I am cruising.
Anyway I was really just wondering if anyone had done this - I think I will just replace with what I have.
Re: Bladder Type Holding Tank [Re: dbows] #7103
03/11/09 08:34 PM
03/11/09 08:34 PM
Highland Park, NJ
Highland Park, NJ
I'm curious if the post '84 models have larger tanks. Mine fills almost the entire forward storage compartment under the v-berth. To my eye, it appears to be significantly larger then the two water tanks combined. Is that what the earlier models have?
Re: Bladder Type Holding Tank [Re: Steve Buzbee] #7104
03/11/09 08:50 PM
03/11/09 08:50 PM
Steve - there very well could be a difference in model years and explain why our perceptions on tank size are so different. I've attached a picture of the space between the aft end of the holding tank and the bulkhead on the aft end of the space. The tank occupies about the forward third of that space and flits flush against the bulkhead by the anchor locker. You can estimate dimensions by scaling from the size of the hose (1-3/4" OD) and the 8-1/2" x 11" paper chart taped on the tank.
You also mention two water tanks. Hull 348 only has a single 18 gallon polypropylene water tank under the port settee.
If Rod Johnstone calls in for the BOG meeting on 24 March, I'll ask him what he knows about the tank sizes.
Sanitary Piping Diagram & Valve Lineup
Re: Bladder Type Holding Tank [Re: Rhapsody #348] #7107
03/11/09 09:59 PM
03/11/09 09:59 PM
Highland Park, NJ
Highland Park, NJ
Great picture-it's possible that my memory may be flawed. I'll have a look this weekend. By the way-that is an immaculate (and complicated) set of hoses!
Re: Bladder Type Holding Tank [Re: Steve Buzbee] #7115
03/12/09 12:30 PM
03/12/09 12:30 PM
Marblehead, MA
dbows Offline OP
dbows  Offline OP
Marblehead, MA
The picture is exactly like mine. Except you could not eat off it as you could Bill's.
Rules Interpretation: Bladder Type Holding Tank [Re: dbows] #11141
02/23/11 02:28 PM
02/23/11 02:28 PM
Barrington, RI
cstoddard Offline
cstoddard  Offline
Barrington, RI
following is my "Rules Interpretation" on this issue
A holding tank is required with a capacity equal or greater to the original equipment (about 14 gallons) The tank must be located in the same location as the original tank. Bladder tanks are an acceptable alternative. Installation for discharge must be in accordance with the current federal and state laws
Charlie Stoddard
Falcon #229
Re: Rules Interpretation: Bladder Type Holding Tank [Re: dbows] #11158
02/24/11 06:01 PM
02/24/11 06:01 PM
Victoria BC Canada
Martin & Louise Offline
Victoria BC Canada
LimeLight hull 51 has a bladder, 14 gal It was installed in the early 90's. And seems to be working just fine and is good for racing. However up in Canda BC there isnt has many pump out as there is in the USA and we find 14 Gal to be a bit small when we are cruising. Thinking about putting in a tank with larger capacity 20 to 25 gal for those summer trips, plus I am not sure what the shelf life of the bladder is and wouldnt want it to fail.
Re: Rules Interpretation: Bladder Type Holding Tank [Re: dbows] #19054
08/07/22 01:38 AM
08/07/22 01:38 AM
Chile
J
Joao Brito CHILE Offline
J
Chile
Hello everyone, I live in Santiago, Chile. I will try to express myself in English. I need a detail of the solution for direct discharge of water from the toilet to the outside. somebody could help me? Thanks a lot
Moderated by  LChristy
0 registered members (), 40 guests, and 0 spiders.
First cruise
Spinnaker Mast Track Needed
by pez. 06/08/23 05:55 PM
Zephyr V2.0 For Sale
by Breezin454. 06/06/23 03:08 PM
Sliding hatch channel source
by Breezin454. 06/04/23 08:31 PM
Replacement table legs
by Navy Dan. 06/04/23 06:12 PM
Fuel tank replacement
by Navy Dan. 06/02/23 05:52 PM
Dockline fairleads
by Patrick Stinson. 05/30/23 09:02 PM
Barber hauler
by Navy Dan. 05/29/23 07:13 PM
Head door
by Steve Buzbee. 05/23/23 05:49 PM
For Sale: 1982 (Hull 434) "ENCOUNTER"
by David Hulse. 05/19/23 09:42 AM
