Re: Main sheet fine tune...again....
[Re: the redhead]
#7036
03/06/09 09:16 AM
03/06/09 09:16 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
Hey Red - Here is the link to a good thread on this. Also it has some photos of my setup which I think is pretty standard and uses most of what you have now. It was the BEST change I have made on the boat. The control you have to shape the main is spectacular. http://j30.us/ubbthreads/ubbthreads.../Search/true/Re_Main_sheet.html#Post3864DB
44
guests, and 0
