Re: Pulpit re-installation – Bedding Compound?
[Re: Rocket J]
#7309
04/26/09 03:24 AM
04/26/09 03:24 AM
dlabrosse
I made my own. Went to the local lumber yard and got them to cut me two 3"x8" pieces of 1" teak. I used the old pieces as a template and cut the slant with a hand saw. I dry fitted them on the pulpit and marked the location to pre-drill the mounting screw holes. Rounded the edges in the sanding stage, cleaned with Interlux thinner 216 (nasty, nasty, stuff BTW) and applied three coats of Cetol. I applied the first coat with a natural bristle brush but ended up applying the next two coats with foam brushes. The thinner is just too nasty to clean the brush with. Even with a VO mask I did not think it was worth it to expose myself and my neighbours to the Xylene fumes.
The finished product is a little less round than the original. But I don't have a router and did not feel like messing about rounding the ends with a hand saw. Generally I am pleased with the result.
[Re: dlabrosse]
#7310
04/27/09 01:53 AM
04/27/09 01:53 AM
dlabrosse
Whoohoo the pulpit repair is complete! Just in time for the start of beer can racing on Wednesday.
[Re: Rhapsody #348]
#7321
04/29/09 02:01 AM
04/29/09 02:01 AM
dlabrosse
Thanks Bill, though t sounds like you've bitten off alot more than I have. That said, having completed this task gives me confidence to do more.
44
guests, and 14
