Battery discharging
#7696
08/10/09 07:53 PM
08/10/09 07:53 PM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
Battery on a salt water boat (i.e. not mine) seems to be discharging. What would be a good way to find the problem?
I can guess either 1 of 2 things:
- it's not being charged... alternator problem.
- it's discharging when not in use... a current leak of some sort.
Any suggestions?
Re: Battery discharging
[Re: Rhapsody #348]
#7701
08/10/09 11:41 PM
08/10/09 11:41 PM
D. Bartley
Chicago, Il. USA
I'm told both batteries are new, so fluid levels shouldn't be a problem.
Can you use an ohm meter across the "house" side of things to look for a current leak?
How about the diodes on the alternator? Is that a likely source for failure to charge?
Tnx muchly.
39
guests, and 1
spider. |
