Question on New Rudder Options
#7664
08/03/09 10:03 PM
08/03/09 10:03 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
I received quotes from the two class approved sources for a new rudder. They offer options that include the following: - Lay-up in epoxy resin: (Standard is Vinyl ester resin)
- High density foam core: (solid core of alternating grain Mahogany)
- Exterior Carbon fiber skin
Any reason why I would want these options? I know the core will be isolated from the start, so should not have water infiltration issues. I'll end up patching the existing water-logged, core soaked, broken rudder to hold me until the new rudder arrives.
48
guests, and 0
