Re: Required equipment checklist
[Re: Steve Buzbee]
#7879
09/17/09 01:09 PM
09/17/09 01:09 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
Steve - you are correct on anchor chain. This is the excerpt from the clarification under class rules para 6.5 The anchor shall be stored in the anchor well. A minimum of six feet of chain shall be attached to the anchor or the anchor line.Here's the measurement checklist link from the 2008 NAs. I sent Larry Christy a proposed update for 2009, but I don't know the status between him and the 2009 NA organizers on the list they will use. The only rule changes for 2009 that may change it is associated with required and optional safety gear. The race organizers have more leeway in 2009 on what can be considered optional.
[Re: Cap'n Vic]
#7893
09/18/09 09:46 PM
09/18/09 09:46 PM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
The center cabin table is certainly not required equipment. Mine hasn't been on the boat since I delivered it from Green Bay.
The sliding table over the ice chest I believe is not generally considered removable... nor are the "wing" tables by the settees. The "bulkhead door" is on the 2008 checklist, and not removable, as are the cushions.
The plastic liners however are not original and can be removed.
Sounds like Marblehead will have a pretty good turnout!
[Re: Cap'n Vic]
#7895
09/19/09 11:36 AM
09/19/09 11:36 AM
Rhapsody #348
The checklist for the NA inspection is merely to help make things go quickly. The class rules are what dictate the requirements. 5.3 Interior Equipment supplied with the standard boat from the factory may not be deleted or substituted for except by equivalent items of comparable weight or as specifically authorized below. Optional equipment offered by the builder or comparable equipment installed by the dealer or owner is permitted as are other items such as shelves or drawers to personalize the interior. --------------------------------------------------------------- --------------------------------------------------------------- Standard interior equipment includes (but is not limited to) the following: - cushions for all berths and settees (V-berth and quarter-berth cushions may be removed for racing)
- stove (In lieu of the original stove a replacement single or double burner stove is allowed that fits where the original stove is located. Adjustments to mounting may be made to accommodate dimension variations, as long as the original intended location is maintained. The replacement stove may use alcohol or gas (butane, propane, etc.). The replacement stove and associated cover / cutting board with fuel shall weigh 18 pounds minimum with weights permitted to augment as required.)
bulkhead door - water tank
- holding tank
- folding tables except main cabin table
- storage bin covers
Optional interior equipment includes the following: - plastic tubs in storage compartments
- teak and holly sole
- main cabin table
- hot water tank
43
guests, and 0
