Re: varnish , non-skid
[Re: Phantom364]
#8282
11/08/09 08:49 AM
11/08/09 08:49 AM
Posts: 140 New Orleans, LA
Rambunctious
New Orleans, LA
The one part non-skid I'm please to report held up nicely. I used Interlux Interdeck. I just wish I'd use cream or biege. The gray is hot in the sun. I going to use beige on the cockpit seats and floor. THen decide if I want to redo the deck.
I've had good luck with Epiphanes also. If you like grey Interdeck, you may want to try mixing the white and the grey - it's not as dark, may be cooler and looks great.
[Re: Bob Rutsch]
#8292
11/09/09 03:37 PM
11/09/09 03:37 PM
JBro
I'll concur with Bill and others on the Epiphanes. In addition to the J/30, I have a '64 Century Resorter, all carvel mahogany plank runabout. 18 coats of Epiphanes. It works well and has some of the best flow characteristics I've seen with varnish. Others may build up more quickly but if you sand between multiple coats, it develops a remarkable, glass-like finish with a durable, UV resistence that will last a long time IF maintained (as Bill explained).
BTW - I haven't taken on the interior on my J/30 but, I was recently looking at a refit done to a Swan 47 where they used the Epiphanes matte finish on top of multiple coats of gloss. Amazing. (if you stack multiple coats of matte, it ends up cloudy, I've been told.)
(and yes - I'm a "finish" junkie. ;-) -Jeff
- Jeff J/30 #426 - Watusi
39
guests, and 1
spider. |
