Re: Jib Furler
[Re: Cap'n Vic]
#8417
11/20/09 09:30 PM
11/20/09 09:30 PM
Posts: 88 Belmont, MA
Georges
Belmont, MA
Multiple sails on furler, Furling AND Reefing, I would not have even consider it by myself. Cool info there. Sail Claus this year. Thanks again.
I have no experience with taffetas, but I guess that I long this is the only part affected by the wear/delamination, that should not be that bad. I definitely do not intend to send $3k a year on sails so I will mention this to the North loft when discussing all this options... Cheers, -- Georges
Re: Jib Furler
[Re: Georges]
#8418
11/20/09 10:32 PM
11/20/09 10:32 PM
Cap'n Vic
Newport and Naples
Once it starts to separate like this that delaminated white film will start to tear and peel off the main. Basically this sail is shot. I will probably buy a race set for Vee Jay 2 early next year. but will not put 3DL on furler again ... never mind any possible use as roller reefing. Please refer your local rep to these photos. I am interested in what their reaction will be to the Best furling 3DL they have. The first week I had this sail I had to return it as the UV cover had been badly stiched and doesn't really match well to the sail material creating bubbles in the foot and leach ... their response is that you really should use a sock and not a UV cover ... That advice I now fully agree with ... although it would have been good to tell me that before I got a sewed on UV cover and they double stiched it to try to make it work. They offered to remove the sail cover and give me a sock... with a lot of stitch holes left in the sail. So that is the second thing I will never do again ... get a 3DL with a sunbrella UV Cover. v
Re: Jib Furler
[Re: Cap'n Vic]
#8422
11/21/09 12:11 PM
11/21/09 12:11 PM
Posts: 83 Waukegan, IL
jhoskins
Waukegan, IL
Vic
Wow that is not the sail I have. I bought a 3DL "Marathon". It is a white dacron sail with the 3DL sail sandwitched inbetween. I cannot beleive you rep speced that sail for a furler! That sail should not be on a furler.
My last marathon was on the boat from 8 years and look like that after 8 years. I was told that was a Pentex Delam problem. I put 1000+ miles a year on Madcap and the Marathon is the way to go. Very durable, great shape, but a little heavier than your sail. I hope to get anouther 8-10 years on my new sail.
I dont have a UV cover to keep weight down. I take it off and flake it or run a sock up if I am going to sail the next day.
John Madcap 358
Re: Jib Furler
[Re: Cap'n Vic]
#8426
11/21/09 06:02 PM
11/21/09 06:02 PM
jhoskins
Waukegan, IL
It is dacron like? Mine looks like that at the right angle you can see the 3DL sail inside.
I would have your rep explain that. They are great sails.
Good luck racing in Naples. That sounds nicer than raking leaves!
John Madcap 358
Re: Jib Furler
[Re: jhoskins]
#8431
11/22/09 09:55 AM
11/22/09 09:55 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
Vic
The Marathon is the way to go if you want to furl a 3DL. We have a full set on the J/42 we ocean race on. They are fantastic and durable. I would never furl my 3 Day Life (3DL).
Re: Jib Furler
[Re: Cap'n Vic]
#8439
11/23/09 09:09 AM
11/23/09 09:09 AM
dbows
Marblehead, MA
Vic - what you took the photo of is not a Marathon 3DL - at least not like the Marthon 3DLs I have seen. The taffeta is heavy duty and is completely opaque, more like a fabric than a milar film.
49
guests, and 1
spider. |
