March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,359 Dacron Main
162,678 Ananda's Refit
Single point lift #8358
11/17/09 01:28 PM
11/17/09 01:28 PM
Milwaukee, WI
Goose Offline OP
Goose  Offline OP
Milwaukee, WI
Has anyone gone to a single point lifting system?
Goose #59
Re: Single point lift [Re: Goose] #8361
11/17/09 05:15 PM
11/17/09 05:15 PM
Watchung, NJ
B Johansson Offline
B Johansson  Offline
Watchung, NJ
I added a single point lift on Fuzzy Wuzzy 5 years ago - extension nuts on the aft 2 keelbolts with eye bolt for each.
We use 2 straps through an inspection port just forward of the seehood and 2 spectra lines from the hook to the stern cleats for some nose trim to keep the rig away from the crane.
Re: Single point lift [Re: B Johansson] #8368
11/17/09 08:14 PM
11/17/09 08:14 PM
St. Margarets Bay, Nova Scotia
Groovin Offline
Groovin  Offline
Any pictures of the lift?
Re: Single point lift [Re: Groovin] #8413
11/20/09 06:16 PM
11/20/09 06:16 PM
Watchung, NJ
B Johansson Offline
B Johansson  Offline
Watchung, NJ
Sorry no pic's - I will try to get a few before the cover goes on next week.
Pics: Single point lift [Re: B Johansson] #8486
11/29/09 09:04 AM
11/29/09 09:04 AM
Watchung, NJ
B Johansson Offline
B Johansson  Offline
Watchung, NJ
Attached are photos of the system we use on FW./Bengt
Picture 033.jpg [179.64 KBytes] - (2809 downloads)
Picture 034.jpg [253.6 KBytes] - (1279 downloads)
Picture 035.jpg [217.24 KBytes] - (2753 downloads)
Picture 036.jpg [226.58 KBytes] - (1249 downloads)
Picture 037.jpg [202.44 KBytes] - (1201 downloads)
Re: Pics: Single point lift [Re: B Johansson] #8489
11/29/09 09:15 PM
11/29/09 09:15 PM
Groovin Offline
Groovin  Offline
Thanks I am looking at doing mid point lift. The strap stopping at the access hatch with the straps from above keeps the stain off the fibreglass from around the hatch. Good idea. 1/2 threaded coupling on two bolts makes me nervous but the strength is probably way more than needed.
Re: Pics: Single point lift [Re: Groovin] #8491
11/30/09 12:15 PM
11/30/09 12:15 PM
Watchung, NJ
B Johansson Offline
B Johansson  Offline
Watchung, NJ
The keel bolts/couplings are 3/4" and good for minimum 12,000# each - the weakest link is the eye bolts rated 6,700# each.
Re: Pics: Single point lift [Re: B Johansson] #8497
12/01/09 12:24 AM
12/01/09 12:24 AM
Highland Park, NJ
Steve Buzbee Offline
Highland Park, NJ
Man that bilge is clean Bengt! I don't have a ledge like that in my boat-did you build that up?
Blue Meanie J/30 #485
Re: Pics: Single point lift [Re: Steve Buzbee] #8503
12/02/09 12:04 PM
12/02/09 12:04 PM
Milwaukee, WI
Goose Offline OP
Goose  Offline OP
Milwaukee, WI
Thank you very much, that is very helpful. How did it pick? Did you have to winch it back at all to level out?
Re: Pics: Single point lift [Re: Goose] #8507
12/03/09 04:01 PM
12/03/09 04:01 PM
Watchung, NJ
B Johansson Offline
B Johansson  Offline
Watchung, NJ
We use 2 Spectra lines to the stern cleats to pull the hook aft about 2" for a slight bow down pick - to keep the rig away from the crane and make it easier to load the trailer - without this it will be a slight stern down pick (OK if the mast is down).
Steve - the sump is too narrow for the aft eye bolt and the aft keel bolt is extended and the area filled with epoxy/glass mix.
0 registered members (), 35 guests, and 1 spider.
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
