Keel Fairing...
#2022
04/24/00 10:39 PM
04/24/00 10:39 PM
Posts: 124 New York, NY, USA
dwl
New York, NY, USA
So,we got our hands on a setof templates, slapped them in place and... The leading edge is slightly fat (about an inch behind the leading edge, it seems about 1/8 inch fat), and significantly (like 3/4 of an inch) short) I gather this is fairly typical. How much work is it to build out the leading edge, and how doe one go about it? Or does this fall into the evil category, where if you have to ask, you should dig out the checkbook and get a pro to do it?
- David
52
guests, and 1
spider. |
