Re: 2GM Heat Exchanger Questions
[Re: Mark Wolf]
#8763
01/18/10 01:34 PM
01/18/10 01:34 PM
Posts: 2,668 Portsmouth, RI
Rhapsody #348
Ok - That's a different question. You really should find out from the mechanic the specifics and why he came to the conclusion he reached. Check this thread on the 2GM mixing elbow.
[Re: Feriation]
#8775
01/19/10 04:41 PM
01/19/10 04:41 PM
Cap'n Vic
Newport and Naples
Ok here is a picture of the 2GMF on Vee Jay 2. the red circle is around the fresh water cap. WHICH by the way is impossible [at least so far] for me to figure out how to take off. I have the feeling the motor mounts may have been replaced with higher ones by POs ... but that is just a feeling. The fresh water pump is at the front of the engine. and the raw water pump below it feeds directly into the integrated heat exchanger which seems to be behind the fuel filter? Have some of the boats had a 2GM or QM with an add on heat exchanger?
[Re: Cap'n Vic]
#8785
01/20/10 02:54 PM
01/20/10 02:54 PM
Rhapsody #348
Vic - I know how to fix that problem. You can borrow my scroll saw to open the clearance on the wood panel when you're back in Newport.
[Re: Mark Wolf]
#8788
01/20/10 08:56 PM
01/20/10 08:56 PM
Posts: 146 Melbourne, FL, USA
Rob Van Name
Melbourne, FL, USA
Mark, The heat exchanger is easy to replace yourself. You'll have to find some where to buy it though because Sendure doesn't sell direct. 12 years ago it cost about $300. See some photos at my blog at http://sailnordicstar.blogspot.com when I changed the hoses to all. A local marine parts dealer can probably order it for you. Rob
48
guests, and 13
