December
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
Amy, Zouheir, Mrks56, Sharon, marco sorio
991 Registered Users
944,264 Dacron Main
153,006 Ananda's Refit
Topics3,908
Posts18,855
Members991
Most Online223
Dec 17th, 2019
J30 Polars #8813
01/23/10 01:14 AM
01/23/10 01:14 AM
Seattle, WA
gmo Offline OP
gmo  Offline OP
Seattle, WA
I just realized that the polars that came on my boat are way different from those on the J/Boats website. For example, the one from the boat is dated 1994 and shows the optimal true wind angle in 8 kts of wind at 144.4. The one on the J/Boats website has the optimal angle at 161.
Newer: http://files.me.com/gradymorgan/gs5aww
J/Boats website: http://www.J/Boats.com/j30/j30polar.htm
Note that the newer is in apparent wind.
Anyone know where the newer came from, and if I should pay any attention to it?
Grady Morgan
Slingshot - Hull #112
Re: J30 Polars [Re: gmo] #8817
01/23/10 07:50 AM
01/23/10 07:50 AM
Rhapsody #348 Online content
Rhapsody #348  Online Content
Reading the legend, it looks like the newer one was obtained under the US Sailing IMS program which appears to be the Performance Products Program now on the US Sailing web site.
I made a jpg so it is easier to see the figures and compare. I also added a picture using the trial version of Expedition that includes a sample J/30 polar. I captured a screen shot and provided both the raw text file Expedition uses, and the file converted to Excel so you can play with it.
I need to get better at using these. Can others post here on how you have used the polars to help your performance?
US Sailing Polar
J/Boats Website Polar
Expedition Polar
J30-Polars-USSailing.jpg [142.58 KBytes] - (17054 downloads)
J/30 US Sailing Polars
J30-Polars-Expidition-Sample.jpg [72.66 KBytes] - (6926 downloads)
Expedition J/30 Sample Polar
J30_Polars-Expedition.txt [0.7 KBytes] - (497 downloads)
Expedition Sample Polar Data
J30_Polars-Expedition.xls [17 KBytes] - (2148 downloads)
J/30 Polars from Expedition - Excel Format
Expedition-data-as-graphic.png [3.53 KBytes] - (5443 downloads)
Expedition data as a graphic
J30 Polars-from UK-Website.xls [18 KBytes] - (2273 downloads)
Last edited by Rhapsody #348; 04/20/10 01:45 PM. Reason: Added J30 Polars from UK website
Re: J30 Polars [Re: Rhapsody #348] #8819
01/23/10 09:22 AM
01/23/10 09:22 AM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
Dacron vs Kevlar ... just how much can that factor change these?
Love those "pinch" curves on US Sailing Polar .... indicates a more sophisticated simulation???
Re: J30 Polars [Re: Cap'n Vic] #8821
01/23/10 11:31 AM
01/23/10 11:31 AM
Marblehead, MA
dbows Offline
dbows  Offline
Marblehead, MA
For short 1-2mile W/L they are tricky to use and probably are a waste of time while you race. I think they are good to look at the relative angle changes as wind increases and decreases vs speed.
For distance races they are imperative because your sailing angles are so important. It is pretty easy to tell when you are beating if you are moving but when you have to crack off and sail 57deg for 4 hrs in 17knts the polars give you a good idea of what speed you should be making. This also will tell you if you are over powered (going over your polar) or under powered (not hitting your polar). Either case you want to change your sail combo to match the polars.
DB
Re: J30 Polars [Re: dbows] #8835
01/25/10 01:39 AM
01/25/10 01:39 AM
Seattle, WA
gmo Offline OP
gmo  Offline OP
Seattle, WA
There's a pretty big difference between the US Sailing polars and the manufacturer polars. Does anyone sail as high in light air as the US Sailing one recommends?
Grady Morgan
Re: J30 Polars [Re: gmo] #8836
01/25/10 08:25 AM
01/25/10 08:25 AM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
7kt, flat seas, NEW light 3DL sails?
and pinch happy ex j24ers?
I am impressed by the use of those pinch curls.
Next time you're out compare barely visible luff flutter to how the woolies work vs speed to two decimal places and contolled heel angle.
I can't concentrate enough to do all of this while driving, and my crew here are no sailmakers.
Re: J30 Polars [Re: Cap'n Vic] #8838
01/25/10 01:29 PM
01/25/10 01:29 PM
Maryland, USA
Bob Rutsch Offline
Bob Rutsch  Offline
Maryland, USA
Using just a compass and a knot meter, we don't fool much with true or apparent wind. I figure we generally tack through a bit more than 80 degrees, which appears to be consistent with these polars.
Re: J30 Polars [Re: Bob Rutsch] #8840
01/26/10 02:32 AM
01/26/10 02:32 AM
Bellevue, WA, USA
R II Offline
R II  Offline
Bellevue, WA, USA
I think the question pertains to 'off-the-wind' sailing angles. Any thoughts on optimum apparent wind angle on a light air run? 90 degrees apparent sure feels good, but how about the VMG?
AC
Re: J30 Polars [Re: R II] #8936
02/09/10 02:21 PM
02/09/10 02:21 PM
Seattle, WA
gmo Offline OP
gmo  Offline OP
Seattle, WA
Yes, I was mostly curious about down wind angles in light air. How deep downwind do you guys typically sail in light air?
Grady Morgan
Re: J30 Polars [Re: gmo] #8941
02/10/10 11:08 AM
02/10/10 11:08 AM
RI
Bob Rude Offline
Bob Rude  Offline
RI
On "Mmmmm" we don't have a masthead wind indicator to record windspeed and/or direction. Nevertheless, we've had the old J30 Polar chart on the boat since we bought it years ago and use it as a guide. We do try to sail to targeted speeds. After sailing for a while, you get pretty good at guessing the actual windspeeds and using that, along with our speedo, we shoot for targeted speeds. On beats, we know what that number should be on our speedo. On reaches, we simply use our Windex indicator which have the jibing angles set. Granted, it's not "data driven," but it keeps us in the ballgame.
Bob Rude
0 registered members (), 36 guests, and 0 spiders.
First cruise
Looking For #1 Genoa
by Cousineddy. 12/05/22 08:43 PM
Looking for Table Arms
by Russ Atkinson. 11/29/22 03:05 PM
#1 Genoa quantum sail $450.00
by GeronimoJay. 11/25/22 03:27 PM
Tiller wiggle
by Cousineddy. 11/12/22 05:57 PM
Mast required asap!!
by John DeGolyer. 10/25/22 09:51 AM
Boat value
by Russ Atkinson. 10/17/22 07:32 AM
2023 NA in Bristol R.I.
by pez. 10/14/22 08:39 AM
Main Cabin and Head Hatches
by B Davis. 10/13/22 03:25 PM
Spinnakers & Misc
by pez. 10/10/22 08:03 AM
Quarter berths
by Rhapsody #348. 10/07/22 08:23 AM
