Re: tuff luff or harken
[Re: Blue Peter]
#8993
02/16/10 12:38 PM
02/16/10 12:38 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
You should be ok if the groove is the same. Class rules permit the foil to be up to 31 mm deep (1.22"): 5.8.1.2 Jib luff groove systems other than that which is provided standard shall not have a fore-and-aft dimension exceeding 31 mm. Here is a Harken spec sheet link
47
guests, and 0
