• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » Racing Tools and Techniques » PHRFof Narragansett Bay
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#9133 - 03/22/10 05:33 AM PHRFof Narragansett Bay
sonskyn Offline
Loc: Apponaug Rhode Island
How can the base rating for a J/30 range from 137 to 144?
I submitted for 155% head sail and roller furling credit giving me a base rating of 144, Spinnaker 147 and non-spinnaker 164. Just curious.
PHRF-NB
Edited by sonskyn (03/22/10 06:22 AM)
Top
#9134 - 03/22/10 06:42 AM Re: PHRFof Narragansett Bay [Re: sonskyn]
Class Co-President
Loc: Portsmouth, RI
Koos - you have a gift rating! For PHRF-NB the base rating for a boat assumes 155% headsail and spinnaker pole same length as J dimension. For a J/30 that equates to 144, although my OD certificate shows a base of 138 with no adjustments. The 138 base is consistent with a 144 base and adjustments of -3 sec/mile for oversize OD jib and -3 sec/mile for oversize spinnaker pole (J + 1 foot). The doublehanded certificate that I have assumes only the #3 genoa is used and the base is listed as 144 which is adjusted to 150 spinnaker, 173 non-spinnaker.
PHRF-NB applies adjustments per this document:
Cruising Headsail +6
Roller Furling +3
OD 163% Genoa (155 base) -3
OD Spin Pole longer than J dimension by 1 foot -3
For One Design, the base ratings are 138 non spinnaker and 155 spinnaker. Assuming since you have roller furling and cruising headsail, your rating is 138 + 9 = 147 spinnaker and 155 + 9 = 164 non-spinnaker
If you reported any changes to the OD configuration, the rating may also be adjusted. I never figured out why the base is listed as different on the certificate for OD versus a non-OD configuration, but the adjustments seem to be consistent when applied as a difference to the OD rating. You may want to send Pat Beausoleil (PHRF-NB Administrator) an email and see if she can send an explanation.
_________________________
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#9143 - 03/22/10 11:48 AM Re: PHRFof Narragansett Bay [Re: Rhapsody #348]
sonskyn Offline
Thanks for the information Bill. Is the double handed certificate based on the use of #3 only or number of crew and #3?
Top
#9146 - 03/22/10 03:29 PM Re: PHRFof Narragansett Bay [Re: sonskyn]
Class Co-President
Loc: Portsmouth, RI
The rating is based on the sail only. Since the 163% genoa is usually too overpowered without crew weight, it makes sense to get the credit and use the smaller sail. If it is real light air, the smaller sail obviously hurts more than helps. That's what PHRF is all about - optimize the rating! You can't switch back and forth between ratings in a series. I use the OD rating whenever I race with crew, and the 110% headsail rating just for doublehanded races.
Bill Kneller
Rhapsody J/30 #348
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Who's Online
0 registered (), 7 Guests and 21 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
