Smoking Diesel
#9139
03/22/10 09:34 AM
03/22/10 09:34 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
So my engine over the last season and a half has started to put out quite a bit of soot. I would say smoke but it does not really smoke more than it has in the past. The difference is that just at fast idle I do not really see any smoke but the transom gets covered with soot. And this can happen with just a hour of fast idle to charge the batteries.
I have changed the oil, cleaned the oil filter, changed the air filter and treated the fuel.
Any other suggestions?
Re: Smoking Diesel
[Re: dbows]
#9142
03/22/10 09:49 AM
03/22/10 09:49 AM
Posts: 2,668 Portsmouth, RI
Rhapsody #348
You may have a clogged injector so that the fuel isn't atomized completely. Try pulling the injectors and cleaning the tips. You can probably just clean them up carefully with a wire brush and solvent. In the worst case, you may actually see a charcol briquette stuck by the pin hole where the fuel gets atomized. There is a picture on page 42 in the Yanmar Operators manual on what the spray should look like. A diesel repair shop can "pop test" the injectors.
Re: Smoking Diesel
[Re: Rambunctious]
#9162
03/26/10 08:40 AM
03/26/10 08:40 AM
dbows
Marblehead, MA
Jason - It is not often that I charge the batteries that way and I like to drive the engine about 2400 rpm. I think I will take my mixing elbow off and give it a clean - as well as give the injectors a quick clean.
Thanks for the help.
David
52
guests, and 1
spider. |
