June
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Benz @ North, David Hulse, littoraldrift, Windchill, knh555
1001 Registered Users
956,033 Dacron Main
156,472 Ananda's Refit
Topics3,945
Posts18,946
Members1,002
Most Online223
Dec 17th, 2019
J/30 Class Approved Replacement Winches #9239
04/06/10 11:11 AM
04/06/10 11:11 AM
Barrington, RI
cstoddard Offline OP
Barrington, RI
J/30 Class Rules paragraph 5.4.1.5 has an "Official Interpretation" annotation that states;
A list of approved replacement winches is available from the Class Measurer.
The list of approved replacement winches will be maintained on the One Design Class Rules forum and updated as necessary.
Table of Approved Winches for the J30 as of 22 August 2011
Winch Power Ratio Weight (lbs.)
Primaries - 2 speed
Barient 25 (Original) 44:1 and 14:1 11.9
Lewmar 43) 43:1 and 15.6:1 12.5
Lewmar 44 44:8 and 13.9:1 12.6
Lewmar 44ST 44:8 and 13.9:1 12.6
Lewmar 44STOR 44:8 and 13.9:1 10.9
Lewmar 40ST 40:2 and 13.2:1 10.7
Harken 40 or 44ST 39.9:1 and 13.5:1 11.9
Harken 46 or 46ST 46:5 and 11.7:1 17.2
Harken 42.2 42:1 and 14.2:1 13.6
Harken 44.2ST 44:1 and 13.8:1
Secondary - 2 speed
Barient 21 (Original) 30:1 and 7.1 9.3
Lewmar 30 30:1 and 7:1 6.4
Harken 32.2 32:1 and 6.8:1 7.3
Halyard - 1 speed
Barient 10 (Original) 7.6:1 3.7
Lewmar 8 7.9:1 3.09
Harken B8 7.5:1 2.31
The table is available to download and print via the attached Word document.
J30_Approved_Winch_Table_1March2011.doc [81 KBytes] - (498 downloads)
J30_Approved_Winch_Table_22August2011.doc [92.5 KBytes] - (725 downloads)
Charlie Stoddard
Falcon #229
Re: Winches [Re: LChristy] #12217
08/22/11 02:01 PM
08/22/11 02:01 PM
Barrington, RI
Barrington, RI
The Lewmar 40ST has been added to the approved list for primary winches
Charlie Stoddard
Falcon #229
Re: Winches [Re: J/30] #12721
12/13/11 05:57 AM
12/13/11 05:57 AM
Apponaug Rhode Island
sonskyn Offline
sonskyn  Offline
I don't see a Lewmar 44ST winch listed on the manufacturer's website. Did you mean the Lewmar evo45ST?
Re: Winches [Re: sonskyn] #12722
12/13/11 07:50 AM
12/13/11 07:50 AM
Barrington, RI
Barrington, RI
with all the new models that have been introduced I will update the list The evo 45 will probably fall in with it
Charlie Stoddard
Falcon #229
Re: Winches [Re: cstoddard] #12723
12/13/11 12:00 PM
12/13/11 12:00 PM
sonskyn Offline
sonskyn  Offline
comparative data
Approved:
New:
Lewmar 45ST Evo 44.8:1 and 13.9:1 7.2kg (Black/Grey Alloy)
Lewmar 45ST Evo 44.8:1 and 13.9:1 9.7kg (Chrome Bronze)
Re: Winches [Re: sonskyn] #12738
12/17/11 12:11 PM
12/17/11 12:11 PM
sonskyn Offline
sonskyn  Offline
the Lewmar 40ST would be a replacement for the secondary and not the primary winches, if considering Lewmar: the hole pattern for the Lewmar EVO 45ST does not match the Barient25; the "Fast Fit" idea was never implemented, no studs supplied. Winches are mounted in the conventional manner.
Re: Winches [Re: sonskyn] #12741
12/18/11 05:41 PM
12/18/11 05:41 PM
Barrington, RI
Barrington, RI
The 40's are not approved for use as a secondary they are two large Power ratio's are to high
Charlie Stoddard
Falcon #229
Re: Winches [Re: cstoddard] #13616
06/13/12 01:31 PM
06/13/12 01:31 PM
Squamish, British Columbia
NaturalHigh Offline
NaturalHigh  Offline
No consideration on Andersons?
Binnacle.ca is having a smoking sale right now beinging the price down to the same as the aluminum Harkens and Lewmars
Re: Winches [Re: NaturalHigh] #13627
06/15/12 09:03 AM
06/15/12 09:03 AM
Barrington, RI
Barrington, RI
I see no reason why we Anderson's can't be approved and added to the list as long as they are in the same power ratio area as the Lemars and Harkins
let me know which one you are looking at and I will review
I did put a new pair of the Harkin 40.25 Self tailers on this year and the crew love them tons of power
Charlie Stoddard
Falcon #229
Re: Winches [Re: cstoddard] #13628
06/15/12 05:47 PM
06/15/12 05:47 PM
NaturalHigh Offline
NaturalHigh  Offline
Anderson 40ST is I think the most comparable. There is standard, standart self tailing, and full stainless self tailing.
Winch Model 40 ST
Drum "D" (mm) 75
Base "B" (mm) 152
Height "H" (mm) 174
Line entry "L" (mm) 71
Line size (mm) 8-14
Weight (kg) 4.9
Gear Ratio 1st speed 1.3:1
Gear Ratio 2nd speed 6.0:1
Power Ratio 1st speed 8.5:1
Power Ratio 2nd speed 39.5:1
Re: Winches [Re: NaturalHigh] #15768
07/19/14 11:31 PM
07/19/14 11:31 PM
NY, NY, USA
Charlie Hurd Offline
NY, NY, USA
Why?
Re: Winches [Re: cstoddard] #17178
03/17/17 07:27 AM
03/17/17 07:27 AM
new haven, CT, USA
bjornson Offline
bjornson  Offline
new haven, CT, USA
Hi all,
I'd like to replace my primary winches. Anyone know if there is an updated list of approved winches? I'm considering the lewmar evo 40ST. The last list I've been able to find is from 2011.
Rob Bjornson
#270 "Bayou Bleu"
Re: Winches [Re: cstoddard] #17182
03/17/17 10:35 AM
03/17/17 10:35 AM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
Hi,
I will update the list of approved winches and post as soon as possible.
Larry Christy
Chief measurer
Re: J/30 Class Approved Replacement Winches [Re: cstoddard] #17189
03/21/17 09:12 AM
03/21/17 09:12 AM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
An updated list of approved winches is attached. The goal is to keep the power ratio's and weight as close as possible to the original Barient winches. Both Lewmar and Harken have changed some of their model numbers but haven't made significant changes in the winches. Alloy, chrome, and stainless are permitted. There was a company in Australia making parts for the Barients. Will try to find a link and post it. Larry Christy Measurerer
March 21, 2017
Winch
Power Ratio
Weight (lbs.)
Primaries - 2 speed
44:1 and 14:1
11.9
   Lewmar 40 Evo
40.2:1 and 13.2:1
8.6
   Lewmar 45
44.8:1 and 13.9:1
10.8
   Harken 40
39.9:1 and 13.5:1
9.6
Secondary â€" 2 speed
30:1 and 7.1:1
9.3
   Lewmar 30
29.2 and 13.8:1
12.3
   Harken 35
36:1 and 13.5:1
7.3
Halyard â€" 1 speed
7.6:1
3.7
   Lewmar 8
7.9:1
3.09
   Harken B8 or B8
7.5:1
2.31
Either alloy, chrome or stainless are permitted
Approved by
Larry Christy
J 30 National Class Measurer
March 21, 2017
Winch Table 03 21 17.doc [35 KBytes] - (150 downloads)
Re: J/30 Class Approved Replacement Winches [Re: cstoddard] #17191
03/21/17 03:53 PM
03/21/17 03:53 PM
new haven, CT, USA
bjornson Offline
bjornson  Offline
new haven, CT, USA
Hi Larry,
Thanks for updating the list.
The Australian company with Barient parts is hutton: http://huttonwinches.com. I was able to get a gear I needed for my barient from them.
Rob
Re: J/30 Class Approved Replacement Winches [Re: cstoddard] #17335
07/10/17 06:05 PM
07/10/17 06:05 PM
Annapolis, MD
ronanderson Offline
ronanderson  Offline
Annapolis, MD
Martec Mark III folding prop
Martec has discontinued manufacture of the prop since April1, 2017. I contacted Gary Beck, owner, today to order a new prop. He will build me one with new and used parts but will soon not even have that option.
He also told me that most of the folding props now use a 1" shaft which my boat has but do not make props for 3/4" shafts.
We need to find a new prop for both 3/4" and 1" shafts!
Re: J/30 Class Approved Replacement Winches [Re: LChristy] #17810
04/24/18 09:27 AM
04/24/18 09:27 AM
BC
P
Pabs Offline
Pabs  Offline
P
BC
Can anyone tell me what length bolts I need for the primary winches?
Thanks
Paul
Re: J/30 Class Approved Replacement Winches [Re: cstoddard] #17815
04/25/18 08:46 PM
04/25/18 08:46 PM
Lincoln, NE
jheinzle Offline
jheinzle  Offline
Lincoln, NE
Can a site admin please move the DOC to the INFO menu section for posterity?
Moderated by  LChristy
0 registered members (), 40 guests, and 0 spiders.
First cruise
Spinnaker Mast Track Needed
by pez. 06/08/23 05:55 PM
Zephyr V2.0 For Sale
by Breezin454. 06/06/23 03:08 PM
Sliding hatch channel source
by Breezin454. 06/04/23 08:31 PM
Replacement table legs
by Navy Dan. 06/04/23 06:12 PM
Fuel tank replacement
by Navy Dan. 06/02/23 05:52 PM
Dockline fairleads
by Patrick Stinson. 05/30/23 09:02 PM
Barber hauler
by Navy Dan. 05/29/23 07:13 PM
Head door
by Steve Buzbee. 05/23/23 05:49 PM
For Sale: 1982 (Hull 434) "ENCOUNTER"
by David Hulse. 05/19/23 09:42 AM
