Halyard Loads
#9389
04/22/10 08:10 PM
04/22/10 08:10 PM
Posts: 42 Seattle, WA
gmo
Seattle, WA
I'm wondering if you guys know how much load our haylards (and uphaul) need to be able to handle.
Looking at the equipment and line i'm currently using, I'm guessing that sheaves and line that could handle 700Lbs working load should be good for a replacement spinnaker halyard.
I also want to replace my uphaul sheaves, and I'm guessing that they should be ok with significantly less (even though the recommendation seems to be 3/8" line).
Re: Halyard Loads
[Re: gmo]
#9396
04/23/10 04:02 PM
04/23/10 04:02 PM
gmo
Seattle, WA
Thanks Bill,
Since the spinnaker doesn't generate lift the same way the foils do, I can't use the formula they talk about there to calculate spinnaker loads. I sent harken an email asking for info. Using the compu-spec tool for a J/30, they recommend a mast base block with a working load of 792 lbs, which is in-line with what I was guessing. Disqualifies that harken ball-bearing sheave everyone's been talking about...
-g
Re: Halyard Loads
[Re: gmo]
#9430
05/02/10 09:47 PM
05/02/10 09:47 PM
gmo
Seattle, WA
I emailed harken about the sheave loads, and here's what they gave me:
> Halyard sheave blocks are going to see a little more load because they turn at a greater angle. I would think the spinnaker halyard sheave would see just under and the jib halyard just over 1,000 pounds maximum working load.
It is really a non issue, though, because as far as I can find, rig-rite is the only place selling replacement sheaves that'll fit my jib-box. They need to be 31/64" wide...
Re: Halyard Loads
[Re: gmo]
#9452
05/04/10 06:33 PM
05/04/10 06:33 PM
gmo
Seattle, WA
I tried to put a harken 1/2" sheave in my pole lift exit block (which uses the same sheaves as the jib halyards) and it wouldn't fit. It also had a much smaller OD which would have required me to drill a new axle hole in an impossible location.
search the rigrite link you sent me for "K-198-8A". This is the top spin halyard sheave.
-g
Re: Halyard Loads
[Re: gmo]
#9480
05/06/10 04:50 PM
05/06/10 04:50 PM
gmo
Seattle, WA
I was just pointing to that sheave to illustrate the size precision. I have wire halyards right now, but plan to move to rope when I replace them. Also, I found a local company that custom cuts delrin sheaves: http://zephyrwerks.com/. Their prices are competitive and the guy was pretty nice and helpful on the phone. I'll post some photos whenever they come in.
44
guests, and 14
