Small Hatch Under Boom
#9446
05/04/10 11:19 AM
05/04/10 11:19 AM
Posts: 678 Maryland, USA
Bob Rutsch
Maryland, USA
We ripped this hatch right out of the deck tensioning a fouled jib halyard at the leeward mark during the NOOD. I figure it's one of these, anyone know which? (And yes I did search the forum.): Bomar/Gray/Pompanette 900 series Or should I go for a low profile Lewmar like we have on the bow?
Re: Small Hatch Under Boom
[Re: Steve Buzbee]
#9490
05/07/10 07:46 AM
05/07/10 07:46 AM
Posts: 15 Alexandria, VA USA
Tom Watson
Alexandria, VA USA
Bob,
I replaced the same size one over the head a year or two ago and found the only drop in replacement was the Bomar. The other manufacturers hatches would require some modifications to the cut out. Things may have changed. I found Fawcett's to be pretty helpful reviewing catalogs and reasonable on price with our discount.
Tom
tom watson
[Re: Tom Watson]
#9491
05/07/10 10:06 AM
05/07/10 10:06 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
I replaced with the lewmars and if you use the ones without flanges then it fits perfectly.
[Re: Bob Rutsch]
#9494
05/07/10 02:56 PM
05/07/10 02:56 PM
dbows
Marblehead, MA
http://www.defender.com/product.jsp?path=-1|6880|6881|320591|368559&id=7052
Ocean Size 10 Flat (No Flang)
[Re: dbows]
#9499
05/07/10 05:32 PM
05/07/10 05:32 PM
Posts: 186 Barrington, RI
cstoddard
Barrington, RI
I've used the Bomar ones Hamliton Marine has the best pricing
Charlie Stoddard Falcon #229
[Re: cstoddard]
#9513
05/10/10 11:51 PM
05/10/10 11:51 PM
dlabrosse
I've broken the handle on the hatch in the head. Might any of you with busted hatches have saved a handle that I might be able to buy off you?
[Re: Cap'n Vic]
#9524
05/14/10 02:39 AM
05/14/10 02:39 AM
dlabrosse
Good idea but I would rather the hatch function as we cruise the boat in the summer as well.
45
guests, and 1
spider. |
