• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » One Design Class Rules » Rules Implication for Replacement Rig Rite Jib Box Assembly
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Page 1 of 2 1 2 >
Topic Options
#9538 - 05/18/10 07:31 AM Rules Implication for Replacement Rig Rite Jib Box Assembly
Class Co-President
Loc: Portsmouth, RI
There has been some discussion on the Replacing Spin Halyard thread about the replacement aluminum Jib box assembly offered by Rig Rite to replace the stainless one that is no longer offered. This is the link to the Rig-Rite page with the information on the sheave box.
I am pasting the text below from the Rig-Rite web page and adding emphasis (red text) for the class measurer to investigate the impact on J/30 Class Rules under paragraph 5.8.2 Prohibited Alternatives or Additions, specifically paragraph 5.8.2.1 which states A headstay length which exceeds 10935 mm when measured from pin to centerline as shown in the following diagram. (See figure 1.)
Text from the Rig-Right page is as follows:
(This is new Assembly)
Aluminum Jib Box Assembly w/ 3/8" Pin: K-11597-1:
Cast aluminum four (4) halyard internal Jib Box Assembly with 3/8" pin and 3/8" Forestay Toggle. Accommodates two spinnaker halyards over two jib halyards, in a trim, narrow and lightweight unit. Features heavy-duty Nylatron Sheaves: (2) 2" Sheaves for Spinnaker Halyards, K-11594; (1) 2" Sheave for Upper Jib Halyard, K-11640; (1) 1 3/4" Sheave for Lower Jib Halyard, K-11639; and (2) 5/8" secondary Sheaves (forward) for the 2 Upper Halyards, K-11585. Jib Halyard Sheaves are suitable for use with wire or rope halyards. All Sheaves are 1/2" wide for snag free handling of halyards up to 3/8" diameter. Assembly fits in mast cutout 9 3/4" high x 1" wide, and fastens with (4) 1/4"-20 machine screws (included). Internal mounting flange is slightly curved to fit a variety of masts. Assembly is designed to fit through the mounting slot and is then fastened from the outside. Forged Chrome Bronze Toggle, Mer 5770-412, is included. Unit measures 12 7/8" long x 1" wide and projects 2" (maximum) inside of mast. Suitable for use with a variety of mast sections on boats with forestays up to 1/4" dia. As used on J/30, J/29F, and others. A2-4, 4-5
(This is old Assembly)
SS Jib Box Assembly w/ 3/8" or 1/2" Pin: K-10658**D:
Welded SS four (4) halyard internal Jib Box Assembly with 3/8", or 1/2" pin for Forestay Toggle. Accommodates two spinnaker halyards over two jib halyards. This heavy Jib Box was used on a variety of MORC boats including many of the J/30’s and J/29F’s. Assembly fits in mast cutout 9 3/8" high x 13/16" wide, and projects 2" inside of mast. Mounting flange is fastened to the Mast with (12) 1/4" fasteners. This part is discontinued, having been replaced by the much lighter K-11597-1, above. A sheave and bushing replacement kit, K-10658SK, is available, see below. Please note: When replacing this item with the new K-11597-1 (the mast cutout needs to be widened and extended downward), the Forestay pin will be 1" higher on the mast; the forestay length will change accordingly. A7-4
I believe that there may be a change to the class rules for allowable headstay length so the mast is in a consistent position intended by the class rules, dependent on the type of jib box installed. Class measurer, please take for action and report your findings. Class feel free to discuss your comments on this topic in this thread.
_________________________
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#9543 - 05/18/10 12:35 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Rhapsody #348]
Bob Rutsch Offline
Loc: Maryland, USA
I suppose we're closing the barn door after the cows are gone. I don't like the idea of the lighter weight or different location but I do live in the real world. Measurer might check if Hall uses this box or some other and where their forestay pin is located.
Top
#9544 - 05/18/10 01:18 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Bob Rutsch]
Steve Buzbee Offline
Loc: Highland Park, NJ
Lighter weight that high up is a pretty serious change if the weight saving is significant.
The headstay length could be corrected by installing the box 1" lower on the mast, couldn't it?
Blue Meanie J/30 #485
Top
#9549 - 05/18/10 03:43 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Steve Buzbee]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
As Class measurer I will be reviewing this issue to see if this box will meet structural requirements, issues on location, impact on the weight, and how it effects the rig tune.
At this time use of the rig rite box is not legal at this time for one design events
Charlie Stoddard
Falcon #229
Top
#11618 - 05/04/11 07:05 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Rhapsody #348]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
After reviewing the avialablity of the orginal sheeve box and alternates As class measurer I recommend that the Rig rite sheeve box be approved for use only in replacement masts. Due to location differences and hole size it can not be retro fitted to old masts.
Charlie Stoddard
Falcon #229
Top
#11626 - 05/05/11 01:06 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Rhapsody #348]
NaturalHigh Offline
Once the availability of the original sheeve box declines and someone has problems with the sheeve box, they will need to replace the whole mast? Ouch.
Top
#11633 - 05/05/11 06:57 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Rhapsody #348]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
Keep in mind that the orginal box is almost unbreakable you may have to replace sheeves and roll pins The only time you would need a new one is if the rig was lost over the side
Charlie Stoddard
Falcon #229
Top
#11643 - 05/06/11 10:13 AM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Rhapsody #348]
dbows Offline
Loc: Marblehead, MA
Charlie is correct. The old one is a beast and there is no reason for it to wear out. All my sheaves were frozen so I pulled the box out and replaced the sheaves. The box was perfect. It also weighs a ton unfortunately.
Top
#11819 - 05/28/11 09:31 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: dbows]
Cap'n Vic Offline
Loc: Newport and Naples
So OK ... now you guys may have a problem ... At some point it appears that kenyon changed the boxes it installed in the mast ... from a 12 screw version to the 4 screw version.
I am thinking it may have been on the last 100 or so j30s often referred to as the 500 series.
The question then seems to be ... if both are "original equipment" they should then be legally interchangeable?
526 was measured for forestay at 2010 NA and it was not a problem .
From memory I think that 505 also has the 4 screw box.
photo of box on 348/349 vintage
SheaveBox526.jpg [52.71 KBytes] - (79 downloads)
Description: installed box on 526
349halyardbox.jpg [45.26 KBytes] - (547 downloads)
Description: installed box on 348/349
Edited by Cap'n Vic (05/28/11 09:34 PM)
Naples
J24 Bang!
NPT
Top
#11820 - 05/28/11 09:38 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Cap'n Vic]
Class Co-President
Loc: Portsmouth, RI
The picture from 349 is the original - same as I have on Rhapsody. The one on 526 appears to be the new one shown at the top of this post. Charlie has contacted Rod Johnstone and the new version is discussed in the 5 May BOG meeting minutes.
Bill Kneller
Rhapsody J/30 #348
Top
#11821 - 05/28/11 09:43 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Rhapsody #348]
Cap'n Vic Offline
This then is an up date to Charlie's post above?
"After reviewing the availablity of the orginal sheeve box and alternates As class measurer I recommend that the Rig rite sheeve box be approved for use only in replacement masts. Due to location differences and hole size it can not be retro fitted to old masts."
Edited by Cap'n Vic (05/28/11 09:44 PM)
Naples
J24 Bang!
NPT
Top
#11822 - 05/28/11 09:46 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Cap'n Vic]
Class Co-President
Loc: Portsmouth, RI
From the minutes, Chief Measurer's report....
  • The Rig-Rite jib box assembly was recommended as an approved alternate to the original design that is no longer made. Rod commented that the location of the head stay attachment should be in the same position on the mast. Measurements will be taken of existing masts to confirm the dimensions.
  • Charlie Stoddard to provide the final class rules wording for the changes above and post on the forum at least 30 days before the next BOG meeting so a formal vote can be taken.
Bill Kneller
Rhapsody J/30 #348
Top
#11824 - 05/28/11 10:19 PM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Rhapsody #348]
Cap'n Vic Offline
Ok ... visual confirmation that the old box was used at least up to #505.
And here I was going to rebuild #526's here in NPT, and exchange for #505's in Oct. Yes, there was some kind of logic behind this discussion.
UNLESS of course 526 was a late replacement mast.
Interesting on how us OD'ers can take some of these things to the outer reaches.
Sheavebox505.jpg [35.88 KBytes] - (120 downloads)
Description: 505 Sheave Box
Edited by Cap'n Vic (05/28/11 10:22 PM)
Naples
J24 Bang!
NPT
Top
#13175 - 03/06/12 11:22 AM Re: Rules Implication for Replacement Rig Rite Jib Box Assembly [Re: Cap'n Vic]
Cap'n Vic Offline
OK ... I'm a little late on this ... at Marblehead NA forestay length with the new box did measure in OK on #526 ... so apparently the change at the factory to the new box took into consideration the OD max forestay length ...
[we had followed up with measurements with masts out, but I can't find that data anymore. ]
Naples
J24 Bang!
NPT
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  cstoddard
Print Topic
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
Who's Online
0 registered (), 7 Guests and 21 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
