• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » Racing Tools and Techniques » Twing Settings
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#9743 - 06/30/10 04:31 PM Twing Settings
Taras Offline
Loc: Montreal, Quebec, Canada
I was just wondering were the racers set their twings
My Jworld instructions on the J24 had them inside the lifelines
Is our J30 the same?...inside or outside the lifelines
Last night in 12Kts true, we had them outside and the sheet / guy had lots of resistance along the life lines and stanchions
I would think they should be inside
Taras
_))
Top
#9744 - 06/30/10 09:45 PM Re: Twing Settings [Re: Taras]
Cap'n Vic Offline
Loc: Newport and Naples
dead down out
broad to beam reach in.
I think that is why we are supposed to use a snatch block on them. Just one more thing to remember to adjust at the wrong time.
_________________________
Naples
J24 Bang!
NPT
Top
#9759 - 07/05/10 07:19 PM Re: Twing Settings [Re: Cap'n Vic]
NaturalHigh Online   content
That is always the problem with a boat that is so wide it has seperate postal codes... on a dead down run you need them outside, but as soon as the pole goes forward you need them inside.
I always go outside because we usually have enough wind for near ddw. My crew also pointed out that pressure on the stanchions/lifelines is probably better than a bunch of pressure on the shrouds.
We tweak the guy and the sheet is free unless we are near out of control. We tweak both for heavy wind gybes.
Top
#9766 - 07/08/10 04:14 PM Re: Twing Settings [Re: NaturalHigh]
Bob Rutsch Offline
Loc: Maryland, USA
As many already know, I advocate leading your sheets inside the life lines and dispensing with the unnecessary complexity of twings.
Put another way, you only need twings if you:
1. Insist on running your spin sheets outside the lifelines,
2. Don’t like to use the foreguy and rely on them so the pole won’t sky, or
3. Think two twings are cheaper than one stanchion mounted snatch block.
Top
#9767 - 07/08/10 04:17 PM Re: Twing Settings [Re: Bob Rutsch]
Rhapsody #348 Online   content
Class Co-President
Loc: Portsmouth, RI
Bob - can you explain #3?
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#9768 - 07/08/10 04:27 PM Re: Twing Settings [Re: Rhapsody #348]
Bob Rutsch Offline
Loc: Maryland, USA
From #3 above--The snatch block keeps the after guy off the shroud when tight reaching, so you only need one. They not cheap so you might be able to rig up a twing for less.
Top
#9769 - 07/08/10 04:31 PM Re: Twing Settings [Re: Bob Rutsch]
Class Co-President
Loc: Portsmouth, RI
Thanks - now I get it. I've got snatch blocks on the twings so could try running inside the life lines and clamp on the twings inside if needed. I may try that and see how it works.
Bill Kneller
Rhapsody J/30 #348
Top
#9770 - 07/08/10 04:46 PM Re: Twing Settings [Re: Rhapsody #348]
Bob Rutsch Offline
Loc: Maryland, USA
I dare say the only reason to twing the sheets down while sailing a broad reach or dead downwind is to control the kite in a stiff breeze. Even then, a little over-trim usually takes care of any death-roll.
Top
#9774 - 07/09/10 04:22 PM Re: Twing Settings [Re: Bob Rutsch]
Taras Offline
I thought that in light to moderate winds, the twings replaced the need for the downhaul to keep the pole from skying?
Top
#9783 - 07/10/10 03:36 AM Re: Twing Settings [Re: Taras]
I wouldn't call it a direct replacement and it depends on how far forward your twings are. DDW it will help hold the pole down but a twing is going to help less and less as the pole moves forward. The downhaul is much more efficient at holding down the pole.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 2 Guests and 1 Spider online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
