• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
      • Diesel Engine Maintenance
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30 NAs
October 18-21
New Orleans YC
New Orleans YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Favorite motor oil?
February
M Tu W Th F Sa Su
Paul_Pasko, DirtFarmer, Sleighride, MPotocki, rhknierim
582 Registered Users
j30news
(Views)Popular Topics
Dacron Main 72706
Northwest one-design 38056
Comment Here - Draft Potential Rule Changes for 2009 24911
Other J/30 Sailboats For Sale 24410
2010 Class Registration & Dues 24307
Rhapsody Transom Re-core and Other Areas Too 21920
J30.org Web Page 18404
2009 J/30 North Americans at Cedar Point YC 17064
J/30 Midwinter and Mardi Gras Regatta 13329
Southern Straits 11243
Forum Stats
582 Members
28 Forums
2518 Topics
Page 1 of 2 1 2 >
Topic Options
#9919 - 07/29/10 12:48 PM Favorite motor oil?
lakesailor Offline
Loc: PNW
As I have been spending so much time around the engine as of late I am going to do the oil next…wondering if anyone has a favorite brand and viscosity of oil in hot climate operating conditions?
I am thinking Mobil 1 synthetic as I have had good luck with it in other applications….
_________________________
http://thej30manifesto.blogspot.com/
Top
#9920 - 07/29/10 02:03 PM Re: Favorite motor oil? [Re: lakesailor]
Class Co-President
Loc: Portsmouth, RI
Oil Viscosity should be as recommended in Yanmar Service Manual for outside temperature ranges – SAE 10W-30 will cover you for most of North America for year round use. If the water temperature is above 95 degrees, use 50W oil. The service grade should be SAE CB or CC for moderate duty diesel engine service.
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#9921 - 07/29/10 02:27 PM Re: Favorite motor oil? [Re: Rhapsody #348]
Mark Offline
Loc: Belleville, IL, USA
I have the older 2QM15. First time I changed the oil I used 10W 30 and it suddenly became hard to start on cold days. Got a lecture from my mechanical engineer dad about reading manuals and did so. I believe it calls for 5W. I used Mobile 1. Starts much easier. ("Started" I suppose since I haven't turned the key in almost 4 years.)
Top
#9923 - 07/29/10 02:36 PM Re: Favorite motor oil? [Re: Rhapsody #348]
lakesailor Offline
Loc: PNW
Unfortunately I have not been able to locate a QM15 manual online….I do know that the GM15 manual suggests 10W-30 I would expect the QM and GM would likely take the same oil.
From most of my diesel experience I have generally found 15W-40 outperforms 10w-30. While on the same theme does anyone know the Fram filter part number ? Once again I am assuming that GM and QM likely take the same filter…
IGNORE the oil filter question....I found the answer in the archives here... it is a Fram PH3593A
Edited by lakesailor (07/29/10 02:38 PM)
Top
#9924 - 07/29/10 02:36 PM Re: Favorite motor oil? [Re: Mark]
lakesailor Offline
Loc: PNW
Do you mean the 5W-50 Mobil 1 ?
Top
#9925 - 07/29/10 03:48 PM Re: Favorite motor oil? [Re: lakesailor]
Mark Offline
It's been a long time, but I think I have a bottle in my garage. I'll check tonight. My mind recalls it just as 5W, but I think you're partly correct. It may be 5W 20. The 2QM runs cooler than the 2GM. This may be the reason. I believe the 2QM was really ment to be a generator engine.
Top
#9926 - 07/29/10 03:56 PM Re: Favorite motor oil? [Re: Mark]
Mark Offline
Here's the marine operators manual for the 2QM15: http://www.g-o.dk/Files/Billeder/PDFer/YANMAR/Instruktionsbger/2QM15.pdf
It says to change with the season, 10W when it's cold and 20W when it's warm, 30 W or 40W when hot, and 50W when REALLY hot.
I really need to look at that bottle.
Top
#9927 - 07/29/10 03:59 PM Re: Favorite motor oil? [Re: Mark]
Class Co-President
Loc: Portsmouth, RI
This from the 2GM Yanmar Operations manual....
oil-suggested.gif [71.97 KBytes] - (206 downloads)
Edited by Rhapsody #348 (07/29/10 09:29 PM)
Edit Reason: Specified 2GM and added link
Bill Kneller
Rhapsody J/30 #348
Top
#9928 - 07/29/10 04:47 PM Re: Favorite motor oil? [Re: Mark]
lakesailor Offline
Loc: PNW
Thanks for posting that link – much appreciated. The only other one I found online for the QM was a broken link.
Top
#9929 - 07/29/10 10:09 PM Re: Favorite motor oil? [Re: lakesailor]
lakesailor Offline
Loc: PNW
Filter Question.....the site here lists a Fram PH3593A as the Yanmar replacement filter....However Fram no longer lists that filter on the Fram website and instead now shows a Fram PH5046 as being the Yanmar OEM replacement on the QM15.....has anyone tried a Fram PH5046 ???
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 10 Guests and 4 Spiders online.
Matching Spins to Timmers
"I wasn't even on the boat, yesterday!"
Final of Hey Jude before launching
Working on crew for 2013 NA in Narragansett Bay
Record holder for gal spin helm
Original cabin table dimensions
by Cap'n Vic
Yesterday at 08:38 PM
Window Replacement
by Cap'n Vic
Yesterday at 08:27 PM
Replace Fiberglass floor or repair?
by CAN106
Yesterday at 02:35 PM
bulkhead compasses to replace?
by Cap'n Vic
02/02/12 01:48 PM
2012 Chicago Mac
by NaturalHigh
02/02/12 12:51 PM
CNBC's Story J/Boats Smooth Sailing
by Cap'n Vic
02/01/12 05:03 PM
Action Video: Vee Jay teens tackle F31
by Cap'n Vic
01/31/12 02:26 PM
Zephyr Version 2.o 2009 Used North One Design Sails For Sale
by forbes
01/30/12 08:58 PM
Prop Shaft Strut replacement
by dlabrosse
01/29/12 11:54 PM
Rhode Island summer regatta?
by Steve Buzbee
01/29/12 11:10 PM
Board Rules · Mark all read
