• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Favorite motor oil?
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Page 2 of 2 < 1 2
Topic Options
#9930 - 07/29/10 11:20 PM Re: Favorite motor oil? [Re: lakesailor]
Rhapsody #348 Online   content
Class Co-President
Loc: Portsmouth, RI
I see the PH3593A on the Fram Website. This is for the 2GM. I haven't played with the 2QM so don't know if it is compatible. The Yanmar 2QM oil filter part number is 119305-35151 or 124085-35113
_________________________
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#9931 - 07/30/10 12:18 PM Re: Favorite motor oil? [Re: Rhapsody #348]
lakesailor Offline
Loc: PNW
You are correct Bill. At first I tried to manually search the Fram PH3593A on the Fram website and got a message that the part # no longer existed. However when I manually went through the Fram website I did find the Fram PH3593A listed as the OEM replacement for the GM15.
It would appear that the Fram PH3593A is NOT compatible with the QM15 as the listed filter for this motor is Fram PH5046. I am going to try and track one down today locally…..
http://thej30manifesto.blogspot.com/
Top
#9935 - 07/30/10 02:47 PM Re: Favorite motor oil? [Re: lakesailor]
NaturalHigh Online   content
I'll look up my filter for the 2QM15 at lunch today.
I just use standard heavy duty diesel engine oil. Pennzoil. I think I put in 20W last time as our PNW waters are not very warm.
On a related note, what oil pressure does your engine run at after it is thoroughly warmed up?
Hot-tip: Home Hardware has a drill-pump for $10 that drains my crankcase in about 30 seconds.
Hot-tip Plus: the 2QM15 installation has enough room to install a drain plug in the pan for easy oil changes. I plan to do this (someday).
Top
#9937 - 07/30/10 03:32 PM Re: Favorite motor oil? [Re: NaturalHigh]
Mark Offline
Loc: Belleville, IL, USA
I found my oil change kit. I've been using Mobile 1 0W 20 since 2001. 6 seasons in the water with that oil only changed twice.
Important note: I sail on an inland lake. I doubt if I've had the engine running more than 30 minutes at a time at anything over an idle that whole time.
I'm going to try to start it this afternoon. Wish me luck, it's been almost 4 years! I'll check to see what oil filter I have on it.
Top
#9938 - 07/30/10 04:04 PM Re: Favorite motor oil? [Re: Mark]
The Fram filter for 2QM15 is indeed PH3493A.
I have been getting enough hours that I need to change the oil every couple months. 2 changes since October.
Top
#9940 - 07/30/10 05:09 PM Re: Favorite motor oil? [Re: NaturalHigh]
last fling IV Offline
Loc: Kailua Kona, HI
WD-40 makes a safer starting fluid. Don't be suprised if you have to bleed the injector system. A drill pump works ok if ytou completly warm up the oil and filter (check side of oil pan) first.
Top
#9945 - 07/31/10 10:41 AM Re: Favorite motor oil? [Re: NaturalHigh]
lakesailor Offline
Loc: PNW
That is good to know...thx....I managed to track down a TG3493A locally....Fram now offers up to four different levels of filter in many sizes....PH, TG, XG and HM.
Wal-Mart had the TH3493A for $ 6 and Canandian Tire had the HM3493A for $ 11
Top
Page 2 of 2 < 1 2
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 2 Guests and 1 Spider online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
