• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Ignition switch replacement?
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Page 4 of 5 < 1 2 3 4 5 >
Topic Options
#9913 - 07/27/10 11:18 PM Re: Ignition switch replacement? [Re: lakesailor]
lakesailor Offline
Loc: PNW
Yet another “quick” question…..tonight I removed the batteries and now have a question regarding the battery wiring…..
Hull #48 has a Rule three way battery switch (i.e. Battery 1 or Battery 2 or both settings)
From a wiring perspective positive on battery 1 switch leads to positive on battery 1. However positive on battery 2 switch leads to the Yanmar and the common 1+2 on the switch leads to the positive on battery 2. This seems in error as one would think the positive on the battery 2 switch would lead to the positive on Battery 2 and the common on the battery switch would lead to the Yanmar. Am I missing something?
The negative is basically negative on battery #1 connected to the negative on battery # 2 and then connected to the engine block ground so that part seems OK.
I am thinking that the battery switch #2 positive should be connected to the battery #2 positive and the battery switch common positive should be connected to the Yanmar. Am I missing something?
I couldn’t find a RULE manual online however it seems Perko follows this pattern.
Many thanks!
P.S. Did I mention I hate wiring?
_________________________
http://thej30manifesto.blogspot.com/
Top
#9914 - 07/27/10 11:37 PM Re: Ignition switch replacement? [Re: lakesailor]
Rhapsody #348 Online   content
Class Co-President
Loc: Portsmouth, RI
I think that's wrong. "1" to battery #1, "2" to battery #2, "Common" to alternator and DC distribution.
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#9915 - 07/27/10 11:44 PM Re: Ignition switch replacement? [Re: Rhapsody #348]
lakesailor Offline
Loc: PNW
That is what I was thinking as well. Currently the common and DC distribution are grouped together only they are coming off battery switch #2 positive instead of the switch common (1+2) positive as I am thinking should be the case….
THX !
Top
#9939 - 07/30/10 05:03 PM Re: Ignition switch replacement? [Re: lakesailor]
last fling IV Offline
Loc: Kailua Kona, HI
No Question! 1 goes to 1 and 2 goes to 2. Both goes to starter or common connectio point. Ground goes to ground in all cases. Any other combination will probably make smoke and cost money.
Top
#9946 - 07/31/10 10:49 AM Re: Ignition switch replacement? [Re: last fling IV]
lakesailor Offline
Loc: PNW
That make sense….I re-wired the switch and corrected this problem yesterday. The way it was in the past battery #1 was hooked up properly however batter #2 was hooked up to A+B and the starter was hooked up to the battery #2 position.
Top
#9947 - 07/31/10 11:13 AM Re: Ignition switch replacement? [Re: Rhapsody #348]
lakesailor Offline
Loc: PNW
All I can think of for the capacitor use is to stop a high voltage arc and prevent burning contacts when the starter button is released. From EE terms it minimizes the dI/dt (change in current over change in time). Kind of like the old condenser across the points in a distributor on gas engines before electronic ignition. The capacitor should do nothing to help or hurt starting performance.
I haven't seen a Yanmar with a capacitor there. It's not shown in any of the service manual prints.
I'm on my 3rd year with a Walmart Group 24 set of car batteries 650 cranking amps that were $70 each when I bought them. No problems.
Apparently the purpose of the capacitor was to serve as an “alternator filter” to help prevent interference for an old MLX Loran the boat no longer has.
I took your advice and picked up a Wal-Mart Group 24 house brand (Energizer) starting battery. 1000 cca for $ 97. For the “house” battery I picked up a Lifeline deep cycle marine http://www.lifelinebatteries.com/marineflyer.php?id=1
I hope to get both installed today and see if my problems are now resolved. Also going to re-check my solenoid connections as well.
Top
#9950 - 08/01/10 02:10 PM Re: Ignition switch replacement? [Re: lakesailor]
lakesailor Offline
Loc: PNW
Another question…
Yesterday I got the new batteries installed…..I am not certain if my problem is yet resolved, however during my checks from yesterday sessions I noticed that only of the two batteries seems to be getting a charge from the alternator when the engine is going.
I am now trying to determine if anyone has an idea why that might be ? Basically the ground on the two batteries is linked together before being connected to the ground on the engine block. The positive on each battery is each connected to the appropriate terminal on the battery switch. And yet once the motor is started only battery #2 will show over 14 volts at the terminals whereas the first battery show the normal mid 13’s range.
I am trying to figure out why this might be or is it common that the alternator only puts out enough current to only charge one battery and the second one to a lesser degree ?
Edited by lakesailor (08/01/10 02:12 PM)
Top
#9953 - 08/01/10 05:21 PM Re: Ignition switch replacement? [Re: lakesailor]
unless you have an isolator, you will only charge the battery that the switch selects (1-2 or both). If you get different readings on both, you may have a poor connection to the lower battery. My old electrical repairman hates isolators (causes alternator problems) I had partial charging until I cut out the isolator and hooked the alternator up to the main power connection at the starter.
Top
#9958 - 08/03/10 12:09 PM Re: Ignition switch replacement? [Re: last fling IV]
NaturalHigh Online   content
Unhook battery number one and just check the voltage on the connector when it is charging.
Top
#9961 - 08/03/10 12:19 PM Re: Ignition switch replacement? [Re: NaturalHigh]
lakesailor Offline
Loc: PNW
I think I figured out the problem…..to my surprise the battery switch seems to have an issue where the switch position for battery #1 seems to have an internal contact issue. You need to really wiggle the switch in position #1 to get the current through. Yesterday once I figured that out and wiggled the switch I was getting over 14 volts from the alternator to battery #1.
I have a new switch on order so hopefully that will be one more thing I can cross off the list. I did get manage to get the oil changed yesterday as well…..and re-wired the fuel tank gauge…..it is always fun crossing off items on the to-do list, although those items being added at the bottom always seem to come quicker……
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Who's Online
0 registered (), 2 Guests and 1 Spider online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
