mattjenPDX71, loic, Cousineddy, Captain Rick, Boat Boxer
915 Registered Users
West Marine Affiliate Link
West Marine - The worlds largest boating supply company!
J/30 Class Affiliate Program
841,936 Dacron Main
127,318 Ananda's Refit
Topics3,730
Posts18,282
Members915
Most Online223
Dec 17th, 2019
Wet bulkhead #18481
05/25/20 12:19 PM
05/25/20 12:19 PM
Morristown, NJ
Sumner_Parker Offline OP
Morristown, NJ
So, I was all set to just add four layers of glass to the ground down part as reinforcing and paint it in place of water damaged veneer. Thought it’s a good time to do something about high moisture readings in the bulkhead. Drilled a few holes… Top of the bulkhead is wet and mush; at the bottom of the long hole in photo it’s solid.
New plan is to cut another inch of the veneer away to the right and then cut across above the hole for the water/wiring, replace the plywood, cover with ten layers of glass, tab into hull and deck.
After drilling holes, appears that the strength of bulkhead for chainplates is in the glass on cabin side. Head side is just a few layers thick. Plywood separates the glass sides and adds compression strength to keep the hull from coming inwards.
Thoughts on:
-how much of old bulkhead core to replace?
-solid glass v plywood core for bulkhead?
-Glass layers, glass type, vacuum bag?
Didn’t see other threads that address this.
bulkhead.jpg [97.22 KBytes] - (198 downloads)
Re: Wet bulkhead [Re: Sumner_Parker] #18494
06/09/20 08:11 PM
06/09/20 08:11 PM
Morristown, NJ
Morristown, NJ
New plan. Removed cabinetry from head side and will replace section of rotted plywood core from there.
IMG_20200609_155244.jpg [103.82 KBytes] - (120 downloads)
Re: Wet bulkhead [Re: Sumner_Parker] #18495
06/10/20 08:52 PM
06/10/20 08:52 PM
Rhapsody #348 Offline
Start reading my old blog at this link, then go to the newer pages in the blog.
Re: Wet bulkhead [Re: Sumner_Parker] #18551
08/04/20 12:32 PM
08/04/20 12:32 PM
Vancouver, BC, Canada
dlabrosse Offline
dlabrosse  Offline
I had a similar issue with 1/3 of my entire bulkhead soaked. The plywood had essentially dissolved. In the end I had a local boatyard cut out the entire bulkhead and replace it. Foam core, glassed along the top (like it shoaled have been in the first place) and solid glass at the chainplates.
Dominique Labrosse
Red Five, #92
0 registered members (), 23 guests, and 1 spider.
First cruise
Fotos Regatas 2017 Tomine Colombia
Regata Armada Tomine Colombia Julio 2017
Wet bulkhead
by dlabrosse. 08/04/20 12:32 PM
Shroud Tension Tuning
by usa1136. 08/02/20 11:01 AM
#484 "Conundrum" for sale
by nathankt79. 07/29/20 07:31 PM
For Sale or Parts #207 Koeshtkah
by Koesh. 07/27/20 02:22 PM
Simple cruising douse
by Rajesh Verma. 07/20/20 07:05 AM
One of the best things about sailing offshore...
by Rajesh Verma. 07/20/20 07:04 AM
WTB: Lower Shrouds (Replacement)
by Rhapsody #348. 07/19/20 12:17 PM
3 way/Y-Valve handle
by Rhapsody #348. 07/10/20 03:53 PM
New North Main - too long?
by Georges. 07/01/20 02:27 PM
How to re-bed hand rails?
by Russ Atkinson. 07/01/20 10:36 AM
