977,822 Dacron Main
163,185 Ananda's Refit
How to re-bed hand rails? #18520
06/27/20 03:56 PM
06/27/20 03:56 PM
Seattle
K
Kellen Offline OP
Kellen  Offline OP
K
Seattle
Okay J/30 newbie question here. I’ve got rain water dripping down the interior ceiling handrails. Do the exterior rails thru-bolt into the interior rails? How do these things come off? It would be awesome if I didn’t have to remove the plugs on the interior rail because finding Ash plugs doesn’t seem like an easy task and I really don’t want to have to re varnish. Can it be done from just the top? Teak plugs are easy to find, and I think the exterior is just finished in teak oil.
Mouse #359
Re: How to re-bed hand rails? [Re: Kellen] #18521
06/27/20 06:19 PM
06/27/20 06:19 PM
Rhapsody #348 Offline
Kellen - they are through bolted with bungs covering top & bottom. I don't think you would be able to remove one side as the opposite end needs to be held to unscrew the nut.
Re: How to re-bed hand rails? [Re: Kellen] #18522
06/29/20 12:50 PM
06/29/20 12:50 PM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
Take the plugs out of the top teak rails, under the plug there is a nut and washer to back off (I had no problem doing this).. Pull top rails off as well as inside rails. Drill oversize holes and fill with epoxy. Re-drill, holes for the screws that are coming out of inside rails - take your time to make sure you center the new holes in the epoxy. Re-bed top and inside
Re: How to re-bed hand rails? [Re: Kellen] #18523
06/29/20 06:33 PM
06/29/20 06:33 PM
Seattle
K
Kellen Offline OP
Kellen  Offline OP
K
Seattle
Thanks for detailed info. Hopefully Russ is right and I don't have to remove the plugs on the interior rails.
Mouse #359
Re: How to re-bed hand rails? [Re: Kellen] #18524
06/30/20 11:43 PM
06/30/20 11:43 PM
Mine were frozen when I had to remove the top rail so I had to remove upper and lower.
Re: How to re-bed hand rails? [Re: Kellen] #18525
07/01/20 10:36 AM
07/01/20 10:36 AM
Rockwood, MI, USA
Rockwood, MI, USA
If it turns out you have to pull the plugs out of the inside rails, I have some ash laying around as well as plug cutters. Just let me know the size of the plugs and how many
0 registered members (), 44 guests, and 14 spiders.
