Re: Deck core
[Re: Phil Spletter]
#18679
02/08/21 08:12 PM
02/08/21 08:12 PM
Posts: 63 Westerly, RI
Chris623
Westerly, RI
Greetings Phil,
3/4". This is the same for the main deck including under the winches, cockpit deck, transom, hull and on at least some boats, the bulkhead to the left and right of the companionway. The 45 degree section connecting the cabin top to the main deck is 1/2", at least on my boat. Under the primary winches, expect to find a 12"x24" section of balsa cored deck that is doubled with extra layers of glass between the main deck core and a lower 12"x24" 3/4" marine fir plywood doubler.
Numerous people have used foam core instead of end grain balsa and there is no short supply of people touting the virtues of each with arguments ranging from never wanting to smell decomposing balsa again to wanting to keep the flexural modulus the same across to sections that did not get re-cored. While I chose balsa, my opinion is that either is just fine as long as the common workmanship topics are addressed such as grinding out 12-to-1 scarf joints to the adjacent FRP, never using polyester or vinylester on top of epoxy, fully scrubbing the blush off of cured epoxy and properly epoxy isolating the new holes you drill to remount the deck hardware.
-Chris
47
guests, and 0
spiders. |
