Topics3,983
Posts19,061
Members1,018
Re: Replacing original 2GM with a 2YM15
[Re: Georges]
#19091
08/22/22 08:09 PM
08/22/22 08:09 PM
Posts: 88 Belmont, MA
Georges
OP
OP
Belmont, MA
Thanks fcd, Thanks Bill,
I have some beginning of answers from Macboring which Yanmar seems to use for its customer service in the US. But still waiting for the drawing with dimension of the original 2GM+KM2A. I did measure over the week-end and found an exact match on the total length of engine+transmission and relative to silent-block attchement. So I am quite hopeful, but I am still a bit baffled of why the 2YM15+KM2P-1 would fit a J/30 model 79 and not a model 84. So your pic and model would help..
Regarding the propeler pitch adjustment if a KMP2P 3.22 was choose - it makes sense - but I intend to stay with the same ratio (2.62) as the original setup - as mentioned also Bill... Will update the thread when/If I managed to have the original 2GM+ KM2A drawings... Cheers,
-- Georges Foot Loose #467 - CPYC - Winthrop
[Re: B Davis]
#19102
09/08/22 10:04 AM
09/08/22 10:04 AM
Georges
OP
OP
Belmont, MA
Thanks B. more pics can not hurt, but I am not sure it will give me more info than what Rob's photos showed. The two open questions really are: * is the engine setup similar on the v2 of the J/30 (~1984 coaming, bigger cockpit - and bigger 1" propeller shaft). * how much drop-in is the replacement when you go with the full package (2YM15+KM2P-1). And picture might not be as helpful (considering of the so many dimension fits involved) than knowing someone that actually did it. But I am already greatfull for the feedback so far... At some point I have to go for it and see how it goes... :-)
52
guests, and 1
spider. |
