978,089 Dacron Main
163,254 Ananda's Refit
Replacement table legs #19203
05/25/23 02:31 PM
05/25/23 02:31 PM
Seward, AK
P
Patrick Stinson Offline OP
P
Seward, AK
Has anyone ever replaced the legs for the original table? The previous owner for my hull 395 had some wonky PVC shimmed with duct tape (real, real wonky). Any suggestions on size, material, and length for replacements?
Re: Replacement table legs [Re: Patrick Stinson] #19212
06/03/23 06:25 AM
06/03/23 06:25 AM
Virginia
Wind Dancer 206 Offline
Virginia
Yes. Originals were corroded at the bottom. Ordered aluminum tubing from Speedy Metals, cut and drilled using the old ones as patterns.
Re: Replacement table legs [Re: Wind Dancer 206] #19213
06/03/23 12:03 PM
06/03/23 12:03 PM
Seward, AK
P
P
Seward, AK
I don't have the original legs. Any suggestion on size and length? I am wondering about how tight the fit was in the top or bottom holes? And were they the same diameter on top and bottom, etc?
Re: Replacement table legs [Re: Patrick Stinson] #19214
06/04/23 06:12 PM
06/04/23 06:12 PM
Portsmouth, NH
N
Navy Dan Offline
Navy Dan  Offline
N
Portsmouth, NH
The legs for my table were made by the previous owner. There’s a carbon tube from a wind surfer mast. It’s 27 3/4 long 2 in od. Into one end is a piece of Al tube 4 in showing and 12 in total so 8 in is jammed into the carbon tube. Al tube is 1 3/4 in od. Overall length is 31 3/4 in. The Al end goes into a tube that’s fiberglassed into the bilge. Dan #409
0 registered members (), 39 guests, and 1 spider.
