Re: Fuel tank replacement
[Re: Navy Dan]
#19210
06/02/23 05:35 PM
06/02/23 05:35 PM
Posts: 63 Westerly, RI
Chris623
Westerly, RI
Atlantic Coastal Welding (Speedytanks) links to the following: http://www.marinesurvey.com/yacht/fueltank.htmwhich should be a good start. Sunshine Marine, Boyd Welding, CL Mattson, Best Fabricators, Ezell Industries and RDS websites might have some good information as well. There is a previous thread on this forum about cutting the tabbing part way up and through-bolting new L-brackets in, but of course, the existing L's that you cut off could be glassed back in. GL, -Chris
39
guests, and 0
spiders. |
