Tbo, allwegot1, MarkandMeg, Charles Prettyma, Jodasailing
1,056 Registered Users
1,102,472 Dacron Main
197,577 Ananda's Refit
Topics4,045
Posts19,257
Members1,057
Most Online620
Apr 9th, 2026
#19495 10/10/25 02:09 PM
G
G Offline
With age, my boom front assembly got a lot of play/wobbling... between the boom tube and the front aluminum cast.
I will use SS inserts to deal with the three screws, like Bill suggested in a different thread, but I still need to improve the fit itself. Anyone has already solved this issue - I would say more permanently than HVAC tape/teflon tape or epoxy film?
I am thinking welding thin aluminium line inside the tube - just because welding is fun...but not too rational...
Cheers,
-- Georges
Georges #19496 10/10/25 03:27 PM
Georges - welding could be the answer but unless you are trained to do Heliarc (inert gas) welding on a thin wall this could be difficult. Perhaps have a thin aluminum sleeve inserted between the boom and the casting to remove the clearance.
Georges #19497 10/10/25 04:26 PM
G
G Offline
Thanks Bill. I start to have a small experience with TIG argon on Laser spars and trailer :-)
Aluminum sleeve would need to be really thin... but I like the general idea to start simple first. I discarded the teflon tape common in the laser class - but then why not... will see how it fares and update.. :-)
-- Georges
0 members (), 41 guests, and 1 robot.
1982 J30 hull 409 for sale
by Navy Dan - 04/17/26 05:09 PM
1980 J/30 - Hull #206 Wind Dancer located in Lottsburg, VA
by Wind Dancer 206 - 04/14/26 12:06 PM
Instrument Panel A Type
by David Erwin - 04/02/26 12:14 PM
1984 J/30 - Hull #428 Black Magic
by johnm - 03/30/26 04:20 PM
J/30 North Americans - Skipper Whitney Kent
by Rhapsody #348 - 03/28/26 06:43 AM
bimini
by Tbo - 03/17/26 11:55 AM
Roller Furling For Racing
by Rob Van Name - 03/08/26 01:01 PM
Insurance for 1981 J30
by Rob Van Name - 03/07/26 11:49 AM
The Spreader Problem
by Rob Van Name - 02/25/26 11:30 AM
by mjr - 02/19/26 12:35 PM
