So OK -- as the windows on #505 are starting to pop out I am in the middle of replacing them
1. The original was polycarbonate ... and has turned a nice frosted glass surface. no need for curtains. Probably could have just rebed them, but because of the work to rebed them i went to the local plastic guy and got 8 windows cut ... all the same pattern for a package price ... [planning on doing 526 in June]
Promo data on Palsun The Polycarbonate available was Palram's Palsun 2UV ... uv coated both sides. which means i can use either side out.
I have seen arcylic crack and glass delaminate and crack ... but then 25-30 year old stuff does seem to have issues no matter what was used.
2. Caulk however has changed radically over the last 25 years so i went with Sikaflex 295UV ... which is designed for polycarbonate. Anything labeled UV is nice down here.
Jamestown distributors How to for 295UV I elected not to do the expensive cleaner and activator ... will let you know if that was a mistake 5 years from now. But from what I see this stuff really sticks to anything it touches.
QUESTION 1 -- on the original panels they seem to have run the outside edge across a grinder to give it a sloppy bevel.
I am doing the same ... but wonder what the logic is behind that?
Question 2 -- on the original panels they seem to have done nothing to the glossy inside bonding edge ... the current advice seems to be to slightly abrade it, which is what we are doing.
![[Linked Image]](https://j30.us/ubbthreads/ubbthreads.php/ubb/download/Number/1072/filename/ePC270002.jpg)
