Rather than epoxying the inside rail, I recommend using a forester bit to over drill the inside mounting holes without penetrating the outer skin. Then tape up the holes and use a syringe with thickened epoxy to fill the holes. The cured epoxy can be drilled and tapped with appropriate SS fasteners to attach the inside rails. Use bungs to cover the screws but don't use glue so they can be removed when desired. Sand the bungs to match the profile of the handle and use a good marine polyurethane to seal everything.
Posts: 190 |
On the crown, Joe specified this to be included (5/8" total crown).
I justed ordered these things - will let you all know how they turn out.
-Dan
Posts: 186 |
I would be very careful about using screws to mount the inside hand rails They should be bolted thought I'm been off shore in a boat were they were screwed in place and resulted in someone breaking three ribs
Charlie Stoddard Falcon #229
the Vee Jays inside handrails are thru bolted with fender washers on the deck ... the outside handrails have fender washers inside. we are fender washer addicts.
Posts: 97 |
FWIW - I'm in the process of replacing ours. The topside teak rail feels pretty soft and I like the reduced maintenance of stainless.
I got one quote from a quality shop to replace the existing rails exactly (5 attach points/rail) in stainless and do removal of old/install of new.
Total price - materials + labor is about $1k.
- Jeff
- Jeff J/30 #426 - Watusi
Posts: 190 |
I've ordered the rails I posted earlier and they just shipped yesterday. I'll post a report once I get them in.
Here is the contact in case I forget:
Mark Reeves The Railmakers Northwest 425-259-9236 - Shop 425-210-1221 - Cell
Posts: 6 |
Charlie, I'm a customer for your teak rails, if you're still willing to turn them out for $300. Laser Beam's on-deck teak rails are shot, but their cabin headliner twins are still in great shape. Halsey Bullen, hgbullen@aol.com
Posts: 97 |
Thanks for posting the contact! They are just north of me. I'm going to give them a call to see what they can do.
Mind if I ask what they quoted?
thanks! - Jeff
Posts: 190 |
Right at $250, shipped to Atlanta. Still havent received the rails but will post with pictures as soon as I do.
Posts: 97 |
Wow - that's awesome. Thanks for sharing. I'm going to give them a call today. Will look forward to seeing the pics.
Thanks! - Jeff
