You can see on Vic's picture the black band on the boom. The inner edge of the band is supposed to be the maximum that the main clew is extended.
I have the same outhaul shackle and it looks like his is pulled to the stop as does mine. His taper looks steeper than mine though (my taper carries further forward). This could be just the angle of the photo.
Refresh my memory, will the OD legal main pull all the way to max outhaul (shackle hits end of boom). Perhaps it is because I have a non-leagl main that was made to measure so it may be a bit longer in the foot.
