1,146,045 Dacron Main
212,918 Ananda's Refit
Page 2 of 6 1 2 3 4 5 6
you can always have two ... You will be suprised at how easy it is to fix everything the second time around.
Here is clean J/30 located in Nanaimo, B.C. Not many for sale in the NW....
http://www.buysell.com/root/detail/...mfortable_10.aspx?gok=Sailboats+23+to+31
Not many for sale at $32.5K either.
Agreed....it seems anything over $ 25K is slow to move.
..and when they do move it is usually for less than $20K.
Charlie Stoddard sent me the ebay link for this. This boat is literally in my back yard - at the marina around the corner from where I live. It's been on the hard since 2002 and needs some TLC. Anyone interested in a second J/30 as a project or parts? Bids close 11 Nov 5pm EST.
[Linked Image from j30.us]
Well Nemesis, Falcon & Rhapsody teamed up but got outbid on eBay to buy KAOS. I stopped by at lunch time Weds and snapped a few pictures. They are shared on my Picasa album with a select few here.
Brand new 3/4" shaft, but no prop
[Linked Image from lh5.ggpht.com]
TSP number stamped on transom with spider web cracks indicate the transom is saturated and need to be recored
[Linked Image from lh4.ggpht.com]
Open holes on aft cabin require recore work there. The companionway cover has about 3/4" gap with hatch boards allowing rain to enter the cabin. Significant water damage occured inside.
[Linked Image from lh3.ggpht.com]
Standing water on teak deck. Water line evident inside up to settee level. A 2" hole has been drilled through hull in bilge sump to drain boat. The teak looks like it would need to be ripped out.
The rig looked ok, as did spars. There was a Hall quick vang below decks. It doesn't appear this boat has the spreader bar fix.
The culprit for wet core - there is a visible gap in the engine exhaust through hull. Evidence of wet core on stbd side below waterline, transom, and stbd side just fwd of transom to the deck level.
Stbd aft spider line cracks indicate wet core froze.
Stbd aft looking forward. Note that core has been crushed and the hull is deformed where the boat has been resting on the poppet.
That propshaft is worth more than the whole boat.
B
B Offline
I stopped in and saw the boat in Portsmouth on Saturday and the extensive interior damage and obviously rotten core would lead me to agree with Dave. It could probably be fixed up to fighting shape but would wind up being more expensive than buying a 30 in better shape.
If the spar is in good shape that might be worth something as well.
