Posts: 457 |
The one inch aft rule is only a class rule. If you sail mostly in heavy air, moving the step further forward won't help you much-in fact it may make you overpowered. If you sail mostly in very light air, having the step another 1/4" to 1/2" forward would probably be a good thing. Of course, if one design is not a concern, you could install an adjustable step that would allow you to slide the step position forward for light, and aft for heavy.
Posts: 11 |
Steve,
An adjustable step would be great. Currently it's set up about 2" from the edge. I think the previous owner did that for the pacific cup race to Hawaii (downwind all the way). I get loads of weather helm and from what I understand, moving the step to 1" will only give me more weather helm. At this point I'm tempted to get a balanced rudder. The trade winds here are fairly heavy, 15-20 kts, usually more on Friday nights.
Erik
Posts: 74 |
I've found that going to a #3 in higher winds not only eases the overpowered weather helm, but gives me about 3 degrees better pointing over, say my 130. Might be a little smaller, but it gives me a huge tactical advantage by pointing higher and being able to do those really quick tacks. 'Course, I didn't have a huge crew to stuff out on the rail and hold her flat, so thatlimited my sail area a bit, too.
Doug Marshall Koeshtkah #207
Posts: 457 |
2" is WAY back at the step. Having the mast that far back at the step probably makes any rig tune guide useless-the recommended headstay length (35'-10 1/2") is probably much too loose with the step in that location. You probably have a huge amount of pre-bend in the rig. I would recommend setting everything per the class standard (step at one inch back, heavy air rig tune at 40/40, headstay at class max). Then play with extra pre-bend by wedging the mast forward at the partners. I have found that the boat balances quite well upwind with those settings (and maxed out halyards and outhaul). What is your rig tune set at usually?
