Posts: 26 |
Posts: 76 |
#228- Starboard gate, added lower gate
Posts: 114 |
Posts: 381 |
Posts: 162 |
I have gates on the starboard side of my lifelines. Not sure if they were standard or installed later. Hull number #92 1979.
Starboard gate was standard in 1981 ... had on #327. then same, same #505 and #526. Starboard is where the launch pulls up as most launches have controls and operator on port side. ... so ok you slip guys don't understand that kind of stuff.
J/30 BOG Member
J/30 BOG Member
Posts: 59 |
Posts: 36 |
#319 has a starboard gate (Upper, not lower) will be adding in a lower this season however.
Posts: 9 |
Hot Chocolate (hull # 360) has port and starboard gates. We find this very convenient when tying up transient docks. I got lucky, one of the previous owners had them installed. However we are about due to replace the lifelines, and the two gates do make the task a little more complicated.
