David - I think David Bows used the same brand I have - PYI Inc. Dripless Shaft Seal - look at this link: http://www.pyiinc.com/
You can get the part number for your application by entering the shaft diameter and stern tube outside diameter. Once I got the part number, I found the best price from Go2Marine.com - you may want to do an updated price search.
David - I will try to get the exact part number. There are two dimensions - the shaft size and the shaft log tube diameter.
DB
#397
Originally posted by dbows:
paint with Silent Running paint I removed about 30lbs of lead from the sound proofing and made a huge improvment in sound dampening down below.
David
#397
Ignoring whether this is removing original equipment, my lead has been duct taped so many times it is a complete mess. Looking at their web page, this sounds like a much better answer.
