Posts: 493 |
David, That was good ![[Linked Image from j30.us]](http://j30.us/ubb/smile.gif)
Posts: 50 |
I've got something very similar to Option 2. It works great.
Posts: 2,685 Likes: 1
Posts: 2,685 Likes: 1 |
Scott - what are the specifics on how you transition from the block mounted on the backstay bridal to how you get the line routed to the base of the cockpit? I don't know if I could bypass the padeye blocks mounted on the stern and run the lines directly to blocks on the floor of the cockpit. Concern would be if the center of effort was too offset from the backstay bridal, or if the path of the lines would interfere with the tiller.
Posts: 78 |
I'll have some pictures to share, if you tell me how to post them.... I read somewhere you need to have a url as the link.. so where do you post them on the web.... Mainsheet and fine tune: [This message has been edited by whk (edited 05-20-2008).]
Stefan - If you don't have a photo site (like O-photo, Snapfish, etc.) email them to me and I'll post them. Bill This is what Stefan sent from another J/30 setup: This is what was sent to me from a Mumm 30 setup: [This message has been edited by Rhapsody #348 (edited 05-13-2008).]
Posts: 649 |
The first drawing is almost the same as what I have except I have two fairleads on each side of engine control panel - as far out to the edges as possible (vs on top). This keeps the line as far back, and as wide as possible at the tiller.
David #397
[This message has been edited by dbows (edited 05-13-2008).]
David - That's exactly the info I needed. I'll mount fairleads aft on the cockpit vertical sides near the top horizontal surface to minimize interference with the tiller. I'll use option 2 (4:1) with a single block at "F" on the diagram and the fairlead replacing the E and half of F. The rest seems pretty straight forward with the cheek blocks and cam cleats.
Thanks, Bill
Posts: 50 |
Mine looks just like the one above. I haven't ever had a problem with the backstay in the way of the tiller, but I can see where it would be nice to keep the line as far aft as possible.
The setup works great. Either helmsman or main trimmer can adjust it easily.
robot. |
