Posts: 179 |
David, The cabin top has approx. a 5/8" curve over the length of the handrail. Was this fact taken into consideration in manufacturing the rails from topsinquality.com or can the rails be bent when installed? Thanks Originally posted by David Erwin: Stainless Steel Hand Rails $150 each Case of Blue Moon $10 Invisable 46' One Design Mast with No weight - PRICELESS!
Posts: 649 |
Originally posted by kooslouw: David, The cabin top has approx. a 5/8" curve over the length of the handrail. Was this fact taken into consideration in manufacturing the rails from topsinquality.com or can the rails be bent when installed? Thanks
The curve was not taken into consideration and no they cannot be bent that much - I tried. DB
Posts: 893 |
Ask Tops in Quality to echo the David Erwin order. We asked them to shorten the middle leg by 1/2 inch. I didn't have to bend it at all. It fit perfectly.
We didn't do this on the original Zephyr and had to bend the stainless rail.
