I've made good progress on the installation procedure. This is work in process. I plan on adding a summary that will flow easier, but will leave the detailed description so people can understand the entire procedure. I also need to make sure everything is correct, once my panel arrives.
I need to take some more pictures to help make this clear for anyone.
Please provide any feed back comments.
Attached PDF document
