That sounds like what you need, if the wire is actually in reasonably good condition. Black is the hot lead and the two whites are the switched lines. Going to LED also means you don't mind using the deck light even when just sitting at the dock. This light just loves to get tangled in lines and sails, so take some steps to keep it on the mast.
