1981 Yanmar Diesel, hull #267. The engine temperature light/warning noise comes on regularly after about the first half hour of operation (strangely enough, it'll NEVER go on when motoring out, only when motoring back in). Raw water strainer is clean. New thermostat installed in spring of 2002 but problem has continued. Does this sound like an impeller problem or should I be looking elsewhere?
Don Rassiger
drassiger@gmail.com
#267
