I need some advice. While pulling out the neutral control button on my engine control, the entire shaft that goes into the unit snapped. It looks like it is a bronze shaft that screws into a threaded male shaft. It doesn't appear that the unit can be repaired. I remember reading about engine controls on the "old" Forum but I can't find anything on the new Forum.
My boatyard can replace the entire unit with a Morse MV-2 unit. Has anyone had this unit installed? They said that if the MV-2 unit is installed, it may need new cables. I'm looking for some recommendations. In the meantime, I'm still able to shift the unit by opening the starboard locker and reaching down to disengaged the neutral lever.
Thanks in advance for your recommendations.
Bob Rude
Goodreader@cox.net
