#10328 10/01/10 10:47 AM
Something to consider; I had a reply to a PM. Looked at the site here several times but did not notice the little flashing envelope indicating the PM was there. Perhaps an email notification, or a larger indication that a reply is available would be a good idea. Maybe I should be more observant. Just an idea, no big deal.
AC
Al - you can set your preferences so you get notified by email when you have a PM. When you are logged into the forum, do the following:
  • On the center top menu click on My Stuff
  • On the expanded menu that appears click on Edit Preferences
  • Scroll down and just above the Time Format click the "Yes" radio button under the question Do you want to be notified via email when you receive a private message?
  • Scroll down to the bottom and click Submit
ps - I modified your settings and sent you a pm to test it.
