#11611 05/04/11 09:14 AM
i recently bought a 1980 J30 and the main sheet is too big so it does not run smoothly. Any idea of the length and material to use for the main sheet ?
thanks
Beppe
PS: sorry if this is a trivial question - but i am just learning slowly
Standard mainsheet is 100' of 3/8" Sta-Set polyester double braid on the 6:1 purchase.
We have 88' of 3/8" Marlow Lionbraid, also a poly double braid, but with a tighter cover than Sta-Set (not something I'd try to splice myself). It has held up for 10 years, but is due for replacement and not available locally. Whatever you choose make sure the line is easy to hold and runs well through the blocks.
You can color code the mainsheet, but it lives outside and will fade in the sun, so white with colored flecks generally is best. Splice on both ends so you can end-for-end the line each year to account for the wear from the cam cleat.
We get away with a shorter length since we also use a mainsheet fine-tune.
I went with black 3/8 Sta-Set, 100'. Under "Articles of Interest" on the main page you will find a rigging article. I find it very handy.
Everyone gives ideas, but what do they cost? 95 feet, cruising, racing or higher racing. You choose,
Samson 3/8 XLS $118.75 3/8 XLS Xtra $223.25 3/8 Apex $232.75
Neil.borne@northsails.com
504 831 1775
Toy Box
