1,179,623 Dacron Main
225,981 Ananda's Refit
#11927 06/13/11 10:50 AM
I have a '79 with the vintage spreader bars with an open end, how do you keep these locked in?
Rig Rite is useless and offered no advice.
Brett - you want to get the spreader bar fix if your boat has not been retrofitted. The J/30 rig has a known problem where the spreaders can become detached and the rig will fail. Check the following links:
https://j30.us/ubbthreads/ubbthreads.php/topics/7122/Re_Has_anyone_replaced_wire_ro.html#Post7122
https://j30.us/ubbthreads/ubbthread...nnapolis_Rigging_Spreader_.html#Post9957
https://j30.us/ubbthreads/ubbthread...rch/true/Spreader_Bar_Fix.html#Post10504
Bill - You are awesome. As always thanks!
Brett
Are are you talking about the inboard or outboard ends ?
The outboard endsnormally have a stainless plate that is screwed in which locks the shrouds in place
Charlie Stoddard
Falcon #229
Outboard, mine are groved in a half circle for the shrounds but open, I am going to use a wire seizing wrap and then purchase the plates or end caps that lock the shrouds into place
0 members (), 33 guests, and 2 robots.
