#11998 06/28/11 12:59 PM
S Offline
The retractable Airmar DST800 is not reading true speed. There is approximately 50% variance between the GPS and Tacktick displays. Too much of a difference to be accounted for currents. It worked fine until I removed it for cleaning. I suspect it is not going in all the way when reinserted resulting in the paddle wheel not getting the full benefit of the flow. Has anyone had a similar experience with retractable transducers?
sonskyn #11999 06/28/11 01:41 PM
Try pulling it again and make sure that the paddlewheel is centered in the slot. If it rubs against the side, it could give an error. You can use a drift pin to push out the paddlewheel pin and clean everything up, then reassemble. Make sure the cups face the right direction on reassembly.
I pull the paddlewheel and put in the blanking plug whenever the boat is tied up, so never need to worry about cleaning the paddlewheel.
