Posts: 493 |
Conumdrum, should this proposal pass, are you going to come to the North Americans? Russ?
Posts: 393 |
Read my comments in the thread about Dacron Mains. It was discussed there. I gave weights of my sails and gave a recommended weight for a string sail (from a sail maker!)
Posts: 393 |
If a rule is passed that makes sense yes (I've already committed). If there is a rule passed with a 30# bag weight (which is senseless) NO!
Posts: 393 |
Please forgive my criptic responses yesterday, I was running out the door to do a race (not on Wildcat, she's in the hospital undergoing surgery to fix her wounds) To Dell; In the thread on Dacron mains, page 11, my note dated 2-23-11 offered a proposed verbiage for rules change - I left the sail weight blank but asked for input. Please read my note on 2-28-11 (page 12). Please read J Bro's note from 3-1-11 (pg 12). And agian, my note dated 3-9-11 (pg.13). My note dated 3-17-11 on pg 14 specifically addresses the weights of my string sails. Notes on 3-22, 3-23 and 3-28-11 (all on page 14) specifically address my dialog with sailmakers regarding sail wieght.
For reference, I spoke to the Doyle sailmaker in Eastern, Mi. I spoke to the UK sailmaker on the west side of Michigan (sorry I don't remember his name) and, I spoke with my sailmaker (Dieball Sails, in Toledo).
I hope this helps.
Posts: 2 |
Hello Dell:
Only racing the J for two years I find the Dacron main refreshing. It may be a few pounds more than a string sail, but I love the durability. My 4 year old North has been through hell and still has great shape, a 3DL or any load path would be junk by now. The shape of a "wing" has not changed in a thousand years. I love Dacron
Sincerely Eric Jones Rifiki
What is all this obsession with 3DL STRING...
KEVLAR!
Posts: 135 |
Seems to me that the 30 lbs bag weight is overly restrictive and does not serve to make the boat more competitive in PHRF fleets (which I presume is the motivation for the change). I'd remove the restriction.
Michael
Posts: 80 |
Have fun with your string mainsails boys. I have seen too many of them delaminate. I am using an old Dacron for rum racing and it STILL has a good shape, and it is very fast. Fancy cloth won't replace using the basic main controls correctly.
Posts: 78 |
I also vote for "no restriction"
For those who are posting opinions on changes to the class rules... Thank you for making your sentiments known.
I encourage each person who has an opinion to contact their district governor to make sure your opinions are properly represented when the Board of Governor's vote on a proposed rule change. The points of contact for district governors are available using the menu at the top. Mouse over "Class", then click on "Board of Governors".
